SC- 1st Gen (1992-2000)
Is it ok to take out the skidplates from underneath?
Old 09-01-09 | 10:48 AM
romeo291's Avatar
romeo291
I took mine off and now I am a happier man.......hope that helps =D
Old 09-01-09 | 01:33 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
Originally Posted by QwkSC
It might actually help. My trans get really hot, I can feel it through the trans tunnel, so removing the under tray might help cool the trans. btw, This a might people, just speculating.
I think you might be onto something. I also think it helps push some air up into the engine bay which helps keep temps down esp. with the turbo/dp.
Old 09-01-09 | 07:21 PM
lowkeySC's Avatar
lowkeySC
i was thinking to take it off too but i kept it on.
it will not make a difference at all on our cars . . . but it was designed to keep road debris from going up & make air flow up toward your engine bay to keep things a little cooler / better airflow . . . but its not enough to make that big of a difference anyways. take it off if its beat up.
and plus with it off when you work on your car and you drop something itll end up on the floor instead of trying to freaken reach down and grab whatever it is.
Old 09-02-09 | 05:23 PM
gmacrae's Avatar
gmacrae
Originally Posted by 5sp_jzz30
youre overthinking it. you dont have a race car. get real.
uhm...no
put of a reason?...yes
worse gas mileage?...would you like to show proof prior to making such a statement
we dont drive rx-7's. if you remove the undertray on those cars they overheat. we dont have those issues.
Of course im not going to show you proof. That would require me to justify your argument.
"we dont drive rx-7s" ?
Ignorance sure is bliss.
Old 09-02-09 | 06:22 PM
MissyLexxx's Avatar
MissyLexxx
Originally Posted by gmacrae
They're definitely put there for a reason. Expect more wind noise, more engine bay mess and worse gas mileage if you remove it.
Worse gas mileage? really?
Old 09-02-09 | 07:51 PM
5sp_jzz30's Avatar
5sp_jzz30
ignorance? if you know anything about FC's you would know that.
justify my argument? YOU are the one that claims/said the undertray removal will reduce gas mileage. if youre not going to show proof them stay the F out of this thread.
....had to do it. you seem to like that one.
Old 09-02-09 | 08:55 PM
Ryeno's Avatar
Ryeno
Banned
it will, this isnt rocket science here.
Without that cover air will go upward into the engine bay instead of passing easily below engine bay = drag.
Old 09-03-09 | 07:36 PM
mr/griffin's Avatar
mr/griffin
it actualy helps areodynamics by reducing turbulance in the engine bay and also the vents create a vacuum that removes hot air in the engine bay. if it is not properly installed then you should just remove it. if its in one peice and you have the propper tools just make a new one i am going to as soon as i get around to it lol
Old 09-04-09 | 05:48 PM
Cleanshots's Avatar
Cleanshots
i took it off and added a Gte to compensate! lolol
Old 09-07-09 | 10:32 AM
5sp_jzz30's Avatar
5sp_jzz30
drag coefficient increases exponentially with speed. considering your top speed on given day is about 80mph and average city speed of 40ish mph.
at those speeds your mpg's arent going to change. on a race car it makes a difference due to the speed. the undertray on the race car also helps with front wheel grip.
so yet again...you dont have a race car.
Old 09-07-09 | 11:48 AM
Ryeno's Avatar
Ryeno
Banned
the point i made was it WILL decrease mpg. I never said by how much because quite frankly i dont know.
It wont matter if you have a race car or a DD; either way removing that guard will create turbulence.
turbulence = drag
drag = your engine working harder to do what it did before more easily.
working harder = using more fuel.
Like i said this isnt rocket science here.
Old 09-07-09 | 02:24 PM
Mortal300's Avatar
Mortal300
Originally Posted by Ali SC3
lol, my turbo helps me overcome any aerodynamic issues....
yeah i think my pt61 def solves aerodynamic issues
Old 09-19-09 | 07:22 AM
EDTUN3R's Avatar
EDTUN3R
Can Say it Any Better! LOL
Old 09-19-09 | 07:57 AM
RyanV's Avatar
RyanV
They aren't needed, but they serve many purposes. It's a splash guard to keep water from soaking electronics. They also trap oil from staining your garage or driveway, they help keep road grime out. The side pieces also help add stability to the frontbumper cover..
I plan on reinstalling mine after I adjust the way the fmic sits.
Old 09-19-09 | 08:05 AM
Pspice's Avatar
Pspice
ok mines is going back on =]
