Help Please. Bulding My Drift Car
Hello, I am planning on buying an sc3 or an sc4 and turning it into a drift car. So i have a couple of questions
First i would like to know which of the 2 you guys think would be better for what i want to do and why
Second i would like to know how i can get about 500-600 rwhp out of the car
Third i would like to know about possible engine swaps like what can drop in what can fit, what needs to be done, pricing etc. and will an ls1 fit into one of the cars
Lastley if the engine swap does happen how hard is it to swap engines in the car
thank you very much i would appreciate if you could help me out
type of car for drifting...matter of opinion
horsepower...turbos are your friend
engine swaps...difficulty depends on the engine and your mechanical ability/plans; half the threads on CL are about them (even LS1 swaps have been discussed)
tranny swaps...the other half of CL threads cover these issues
any of these broad questions will get you under fire quickly because someone asks the same thing every single day, but anything specific (reasonably) and you're bound to get a mountain of advice and support
X's 30!! with the questions you are asking seems to be simple enough information to search for.
The SC is a heavy car, yes it can drift but paired with the questions you are asking (in 2 identical threads) plus the weight and cost, an S13/14/FC/FD might be easier to comprehend.
If you already know how to drift, and dont mind a heavy car and money isnt really an issue..
GTE swap paired with r154 trans
convert fromt twins to single
coilovers for a TT Supra
LSD
DRIFT...
LSD
DRIFT...
LS1? go buy a GTO, its got an LS2
Your welcome....Now read! read read read!!!
Your asking questions that 80% of people here asked too. They read these pages...and so shall you.
Edit...I just saw you made a second thread about the same thing. Read these before you post again.
https://www.clublexus.com/forums/sc-...lick-here.html
https://www.clublexus.com/forums/att...rules-2005.pdf
Either engine has enough power for a beginner to learn drifting
My suggestion as far as upgrading is the suspension and drivetrain.
concentrate on the LSD and coilovers for starters
the go with suspension brace and lightening the drifetrain so you can make use of that stock power
my HKS powered S-14 which had 400rwhp only lasted me 2 months because i was a begginner drifter
but my stock 180sx only had suspension and drivetrain modification and that thought me a lot in getting better at drifting.
concentrate on getting better at drifting before puttin anymore money on the car cuz any drifter will tell you
you will crash your car....the better you get at drifting the less likely you will total your car but that don't mean you wont crash
GOOD LUCK in drifting
if you need any more info on drifting hit me up
i'm building my IS for drifting and show
but the IS is my 5th car after drifting and crashing 5 previous cars
theres a diy and a writeup for absolutely everything you could ever wana do to that car in 800 places across the net and parts are cheap and abundant.
i agree...but for a (what seems like) a beginner who doesnt wana do too much research what better route to go then a 240?
i would suggest the 240 fastback and not the coupe
even though they share the same chassis
the coupe or S-13 model seems to have a lot of understeer issues
and it takes more suspension work to get it in better shape for drifting
while the 180 model has a perfect balance for drifting as is with minimal upgrade.
