Retrofitted Projectors
updates
what i have may be kinda questionable but trust me it works pretty well!
Yes i had to cut some material out near the leveler window! but it took me a while to just get it mounted a decent way i have a winner. Due to trail in error i pretty much gutted my right side headlight so i am looking for a set on ebay oem donors. Only way i would have known how to get what i got was trail and era so hopefully someone saw what i did wrong and just do what i did right! Hope this is helpful!
clean up the lens with some blue magic and i took the bezel from from the oem projector which was 3"since the fx is 2.5" need a good way to make up for the clearance it worked out pretty well and i rtv it to the inner housing of the light and a front on image of the clear projector
here is a shot of the output against a wall the glare kept arcing the cut off line idk why? But mind you this is only from one headlamp and the output is that bright so wait til i get them both done! i will take the pix with a better camera next time!
it was actually easier than i made it i just would say if you are thinking of the retrofit proceed with caution! I couldnt mount them with the mounting points or tabs i had to remove material from the inner working of the housing and the worked it into the perfect position but i really couldnt use bolts or screws but its wedged all the way back in the desired position then i use some adhesive to hold it in place. im debating whether i should put some screws in for extra support but it seemed to line up pretty nice!
from the way it appears no i wont be able to adjust them unless i trim the projector more (dont want to do that) but i have the bi xenon so that my fail proof plan. i just have to make sure its done rite the first time
