Retrofitted Projectors
#31
If you use a common projector like the tsx there are mounting brackets available from Luxurymod(I think?) which makes the retrofit super easy. It bolts up to the stock adjusters and allows you to use those to align the projector.
How level the cutoff will be is based on how the projector is mounted. Its not hit or miss if you take the time to adjust the rotation properly.
#32
I guess it's going to take a bit more time and delicacy being unable to use the stock adjustment bolts
#41
Well my initial plan was to have my high and lows in the same housing (reason for bi xenon) remove my fog lights and replace my inner light with 3k hid kit and hard wire those lights either in with my bi-xenon hi out put only or do a separate wire configuration! I bought some new headlights from japan im going redo and cut out all the errors but dont worry this will be well documented!
qha_vn
81
10-07-16 03:22 AM
CAN-Toronto Fs:m35/45 projectors with l/m brackets
shurian
16
12-15-13 12:45 AM
Kzoosho
03-29-12 09:29 AM
