what to do when passenger door doesnt open??
Ok so i tried to get the passenger door open but no luck the inside handle broke off caused by my older brother,the door used to open but you had to put your shoulder into it to push out.
When you roll the window down itll stop halfway,when you try to open the door with the latch you can hear it tap the glass window?
So I dont know what else to do with this door...unbolt the door from the fender?? i dont what else...
use the search a little bit like mentioned, this is a common issue..
also quit rolling your paasenger window down, if it hasn't already damaged the rod that goes into your door handle, putting your window down will just make it worse..
ive searched before and i know how to fix it.
But i tried takin the rear interior panel out to make room to try and get the door panel to pry open......no luck so i guess my passengers will have to crawl into the passenger seat. :/
Now if is a problem the just the door handles just remove the the black piece of plastic by the orange sticker (Pop it with a flat head), You know the orange you see when the door are unlocked. There will be screw unscrew it. After you've removed the handle there will be two cords (They look like throttle cables) pull on the blue one, open the door. I'm not telling what to do but if I was you, once the door opened pull apart the whole door and take a look at the door actuator, If that bar is bent chances are your door will need a replacement. I just tried to fix myself and unless you know how weld Holla at ALGA he hook me up with one and I done with this in one hour.
ok ill give it a try again,i already left the 3 screws off on the bottom of the door panel,just unscrew the door handle,door light,and the screws on the handle.
Dougg62
01-01-12 02:24 PM
