2JZ-GTE Vs. 1UZ-FE
Hey Gang,
I was wondering how strong is the 1UZ block. I know the GTE is a very strong block in stock form. Anyone know how strong is the 1UZ? If we turbo 1UZ, how much power can it handle?
HKS has a 1479hp 1UZ-FE(well actually the 4.3l 3UZ-FE version but basically the same engine) so if the internals are upgraded properly then the car can obviously handle big hp. Big hp reliability on that engine is yet to be seen(i.e. daily driving).
It can take lots of power. This austrailian drag boat thing, which was running a 1uzfe with twin centrifugal blowers pusing around 700hp. However it did have some thick head gaskets to lower the compression to 7:*:* on a stock bottom end.
Yeah that makes allot more sense. Bean maybe you meant those Australian cars were running the 900 hp on a stock bottom end which would apply for Supercharged cars. Turbo setups(since they run off the exhaust, not pulleys) require upgraded internals(i.e. fuel injectors, intercooler, etc...) to handle big hp.
I am thinking about supercharging my 1UZFE. I was thinking about 18-22 psi. Pushing the engine right under the limit. If the 1UZ as strong as GTE, then i can focus more on the 4.0 instead of 3.0. Hey 1UF is already 1 litter ahead already. Anyone know where i can find strong internal parts for 1UZ? i.e. Crank, rods, pistons, rings. I am thinking about working with a hi-pro specialist and create a Supercharged Kit for the 1UZ. This what i have in my mind:
Headunit: ATI P1SC -Self Contained. No oil needed, no water needed either.
Bracket: Custom made
Intercooler: yes, we can use ATI 3 core sheet metal intercooler
Ignition: MSD Dis-4
Injections: Would Supra injectors fit into 1UZ?
Fuel: Waldon 255 l/h and external pump
MAF: Stock or after market with reprogram
ECU: That is beyond area. Anyone know.
If we have a strong engine, regardless Turbo or SC, the engine will made insane power. I feel SC is more approciate for the 1UZ due to space and potential heat problems.
Ignition: MSD Dis-4
I think SC is much easier than Turbo, although SC might produce slightly less than Turbo. If i can get 700 rwhp with SC and 800 rwhp with ST or TT. I will settle with SC. If i can have my mechanic produce a SC kit, anyone interested? It will fit SC400 and LS400. As i stated earlier, the only problem we will face is ECU. Hardware is easy.
The kit i am visualizing will be clean and stock looking. With 15 psi we will double our stock hp and 30 psi we will triple our stock hp.
Well Bean,
The swiftracing car did 700flywheels horsepower over a year ago? Just by natural progression, they should be in that 700rwhp range by now(1000hp)...if that.
Also Clint's SC300 has a T76 turbo which also will be doing 700-800rwhp and it fits in the engine bay.
I really hope that the race between Clint's sc300 and Muhammads GS400 happens one day. I would PAY to see that.
very doubtful
I hear that SRT keeps blowing up EVERY motor they put the big blower on
there are no SRT cars running around with 700 flywheel horsepower reliably... they all blow up; thats why the setup is not available
Clint's old car made 765rwhp... this one should make a good bit more; SW runs a T72 and ran mid 9s @ 153mph; Clint has a bigger turbo![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
765rwhp equates to 900bhp![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
the race between Clint's new SC3 and Mo's GS4 would be a joke imo
not that I don't like GS4s; I just don't like the idea to go against the grain for no other reason than to just go against the grain; both motors are perfect for turbocharging; and turbos are so much better than centrifugal blowers in every way
if Mo (that's his name right? never met the guy) had spent as much time on a TT kit for the 1uz as he did on a SC car; he'd have something...
