SC- 1st Gen (1992-2000)
sc400 Traction control
Old 10-04-09, 09:36 PM
mr2fast4u
mr2fast4u's Avatar
Default sc400 Traction control
ok so there is no traction control option that i can find. new owner. is there a way to swap trannies so that you can have the option of turning it off? i would like to get a little wheelspin out of it if i can lol
Old 10-04-09, 10:28 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
If you have TCS you should have a button near the shifter if I remember correctly that says "TRAC" or something like that. You press that and your TCS should be turned off.
Old 10-05-09, 06:00 AM
dizzyroc
dizzyroc's Avatar
if you dont have traction control why would you want to install it just to turn it off again
Old 10-05-09, 06:48 AM
Jeembo
Jeembo's Avatar
You have TCS but you don't have a button to turn it off? If there is one, it would be under the steering wheel (at least that's where it is on mine).
Old 10-05-09, 09:15 AM
Neucorp
Neucorp's Avatar
SC400 = granny transmission. Do a search for torque converter.
Old 10-05-09, 05:48 PM
mr2fast4u
mr2fast4u's Avatar
ya i want to turn the traction control off. cant find any button near the shifter. this thing wont break loose at all.
Old 10-05-09, 06:16 PM
SC_coupe
SC_coupe's Avatar
The TRAC OFF button to the right of the shifter does it. If your car has TRAC, it came with one of these switches. Otherwise, it doesn't have the option. The only other possibility I can think of is if your center console was somehow damaged and replaced by the previous owner who installed one from an SC without traction control, thereby covering up the switch. Alternatively, the entire system can be removed from the car if you desire. One question: Are you getting the TRAC letters flashing in your tachometer as your trying to accelerate quickly?
Old 10-05-09, 11:04 PM
Dispin
Dispin's Avatar
These pictures show where the button is located and what your dash would look like if you turn it off.
Old 10-06-09, 09:50 AM
Neil4Speed
Neil4Speed's Avatar
If yours is a 98+ the trac button is under the steering wheel on the left side (closest to the door)
Old 10-06-09, 12:13 PM
SHOLEXMAN
SHOLEXMAN's Avatar
Hey new guy it would help to tell us the year of the car....
In the earlier years of the 1uz-fe the covers by the throttle body shown in the picture below have covers next to them. The covers either say nothing cause there is NO trac control or it would say TRAC indicating that there is traction control. Check under your hood and see if it is there saying that you have a earlier year model. If you don't you might need to have some maintenance done since you might have lack of HP.
http://www.celtasoft.nildram.co.uk/c...t/Dsc00127.jpg
Old 10-06-09, 01:30 PM
GRN MNSTR
GRN MNSTR's Avatar
Location: Marietta, Georgia / Charleston, South Carolina
Exactly what I was going to say. I found mine by accident lol when I got the car just pressing random buttons and what not to see what everything did lol
Old 10-06-09, 05:12 PM
Black Fire
Black Fire's Avatar
Switch off the Trac and O/D and the wheels WILL spin.
Old 12-26-09, 06:02 PM
anhtuan904
anhtuan904's Avatar
I have a 95 sc400, TRAC OFF light on cluster(but not flashing), NO TRAC OFF button, and cover about throttle body doesnt say traction controll. So not to sure if i have traction control... getting mixed signals here because of the TRAC OFF on my cluter(again not flashing). Is there another way to find out if i have traction control? I want it to be turned off only when i would like but if i just dont have a bottun i want to turn it off.
Markmorbid
10-07-17 09:41 AM
SC300_704
Performance & Maintenance
11-04-16 09:00 PM
c33w
09-14-10 07:59 AM
vietstuh
14
06-01-06 09:20 PM
Quick Reply: sc400 Traction control
