96 SC300 Door open sensor location?
Passenger side door courtesy light won't go out. I figure the door open sensor is stuck, but can't find the darn thing. And yes I have searched this site for answer, but have found nothing..
Keeper of the light
Inside the door lock assembly, searchy, searchy........ I know you say you did, but the info was posted less than 2 weeks ago so ........it's here .
https://www.clublexus.com/forums/sc-...oem-alarm.html
All I put in was "door lock " in SC forum for search.
some dome light searches revealed it as well.
I was afraid it was going to be in the door actuator which I just replaced..Thank you so much for the tips and link.
Mr. O.L.T. - I suppose I am not searching correctly, since using 'dome light" doesn't yield any easily apparent reference. And I would not know to use 'door lock' since I didn't know they were tied together in the first place.
