Clutch pedal Return Spring
Hey guys i recently just found out the reason why my clutch pedal keeps sinking to the floor. I was just wondering if you guys had ever replaced the clutch pedal return spring that is directly connected to the pedal? I really need help so if you guys can give me any id highly appreciate it. THANKS
you need to take off the pedal first. There's a 14mm bolt with nut all the way at the top which holds the pedal on the bracket. after that there's a clip on the pedal with a little small rod looking with thing which secures the shaft from the clutch master cylinder on to the pedal. Once you take that off spring should come right off.
estomax
Performance & Maintenance
05-18-13 03:00 PM
rwdanthony
01-12-09 08:34 PM
95 Integra
12
12-13-05 07:28 PM
