SC- 1st Gen (1992-2000)
please help with rims and tire fitment thanks
Old 10-11-09, 12:51 PM
ISALEX
ISALEX's Avatar
Default please help with rims and tire fitment thanks
hi im a newbee to CL and wanted to get either 350z or g35 rims for my 1996 sc300 but wasnt sure if they would fit heres the spec on the 350z Touring 18" v.2 5 spoke which came out in 2006-2008
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
and the g35 coupe 7 spoke
Front
Offset: +30mm
Weight:
Tire: 225/45/18
Rear
Offset: +30mm
Weight:
Tire: 245/45/18; 265/35/18 will also fit
would these size tires and offset fit without any modification on the car and does anyone have these on there cars that they can post pics of to see how they look i would really appreciate and thanks everyone in advance
Old 10-11-09, 01:18 PM
FutureSC
FutureSC's Avatar
Well welcome to CL! There's already a thread on this stickied, but both of those sets of rims will fit and they will be sunken. You will need spacers.
Old 10-11-09, 01:19 PM
HeisLegend
HeisLegend's Avatar
No modifications.
Just slap and ride.
Old 10-11-09, 03:16 PM
ISALEX
ISALEX's Avatar
thanks everyone for the info does anyone have pics of them on the car by any chance it would be very much appreciated also are the tires going to rub if i put spacers
Old 10-11-09, 03:36 PM
DryBlaze
DryBlaze's Avatar
What size spacer, on which set of wheels?
Old 10-12-09, 12:00 PM
ISALEX
ISALEX's Avatar
im not sure what size to use with this setup t make the come out what do you guys think. like i said im a noob and dont know much thanks
Old 10-12-09, 12:11 PM
FutureSC
FutureSC's Avatar
I'm pretty sure that the fronts wouldn't need spacers to fit the fronts but the rears would be around a 10 - 15 mm spacer for both sets.
Someone else correct me if I'm wrong
Old 10-12-09, 03:37 PM
fliptrix
fliptrix's Avatar
you won't need spacers in the front.. unless you really want them to be flush, then then you'll need to shave or roll your fenders. And for the rear, yeah you'll probably want a 15mm spacer. Other than that you can just put them on and be done with it.
I can get pics of my car in a bit with the 18" g35s if you want. I am running 225/40 in the front and 225/45 in the rear. I have slight rubbing in the front on turns with bumps for some reason lol. Also I'm lowered on Espelir ASD. And yes my sig isn't updated with the g35 wheels yet.
Old 10-12-09, 04:41 PM
ISALEX
ISALEX's Avatar
yes i would appreciate it if you put up pics and thanks for the info also could you teach me how you put up your pics on here because i have no clue also what do they mean when they say it will look sunken?
Old 10-12-09, 04:57 PM
WoRKeDiT
WoRKeDiT's Avatar
what size tires are on the wheels, i had some 350z wheels on my coupe a few months back and it looked really good, almost flush with no spacers. I had the 6 spoke 1's though.
Old 10-12-09, 06:22 PM
ISALEX
ISALEX's Avatar
do you have the pics of that and what size tires did you use i want to use the stock tire size would that work
Old 10-13-09, 04:31 PM
fliptrix
fliptrix's Avatar
Here's some quick pics:
quick side shot:
here's how the front sits (tires-225/40/18):
this is how sunken in the front will be:
how my rear sits (tires-225/45/18):
this is how sunken in the rears will be:
kinda hard to tell, but this is how close the fender is to the tire:
My SC is lowered on Espelir ASD's.. so if you're running the stock height, you shouldn't have any problems at all.
Old 10-13-09, 04:39 PM
fliptrix
fliptrix's Avatar
correct me if I am wrong, but I don't think you can fit 265 on 8.0in wide wheels. pretty sure you can only run 215 to 245 on an 8in wide wheel.
Originally Posted by ISALEX
g35 coupe 7 spoke
Front
Offset: +30mm
Weight:
Tire: 225/45/18
Rear
Offset: +30mm
Weight:
Old 10-14-09, 01:09 AM
ISALEX
ISALEX's Avatar
im not sure those are just the specs that i found online when i searched the z wheels and infiniti they were on a z forum
Old 10-14-09, 01:16 AM
OneJay
OneJay's Avatar
I'm running that size on my rear wheels, but they're 8.5". I would go 255 at the widest on an 8" wide wheel.
Quick Reply: please help with rims and tire fitment thanks
