96 sc300 stock should i change the timing belt
Hi everyone i have a 96 lexus sc300 the car has a little over 23k miles on it i was wondering if i should change the timing belt or its fine for now. also is there anything else i should change while im doing the job since the car has such low miles thank you.
96, 23K miles... hhmmm "Original Miles"? or did you mean 230K miles? It could be time for many other maintenance other than just a timing belt change.
But if that was original miles, I guess the belt are just too old if the car has been sitting a while and not driven or started regularly.
Good luck.
Good luck.
no i meant 23k original miles i took some pics but dont know how to put them up the way everyone else does it was driven under 2k miles a year which is not that much and its really clean. so you guys think it needs the timing belt changed and anything else you can think of will help but under the hood looks brand new so thats why im asking you guys. also if anyone knows how to put up pics please let me know it would help thanks
yes!!! change it! Belts and tensioners go bad over time... regardless of miles. They dry-rot if they're stored improperly/outside, tensioners fail from old age... please please please for the love of your engine, do a full tune-up and timing belt service.
