1. Cluster backlight and all needles are dead
2. Driver's side door panel is held together by epoxy
3. Driver's side power window motor is slowly dying out
4. Driver's side window switch needs to be yanked really hard to work
5. My in-dash dvd has
Other than that it idles really smooth still
You can just put in new bulbs if your cluster backlight it out. Few bucks for bulbs unless you use LEDs.
94 sc400 252000 miles used transmission 251k miles ( I put in dex 3 after running it low and being neglectful ) Rebuilt moter ( dumb should have just replaced the valve stem seals and lapped the valves instead since after taking it all apart it turns out these engines are extremely well built ) Everything has fallen apart on mine ( mostly my fault for dating the wrong women and buying a car that hadnt been taken care of) but I love her and I will always put money in her ...
these cars are really strong, and i really like that they are non interference motor(2jzge,1uz W/O vvt-i), pop the timing belt, no worries, line it back up and replace.
