SC- 1st Gen (1992-2000)
DDM Headlight HID Kit Intermittent Lighting on Passenger Side
Old 10-13-09 | 04:55 PM
snook's Avatar
snook
Default DDM Headlight HID Kit Intermittent Lighting on Passenger Side
Has anyone experienced this problem? My passenger headlight sometimes doesn't turn on, the drivers always does. If I turn the lights on and off it comes on. I have a 1996 manual if that makes a difference.
Over the phone they told me I should be the accessory harness but werent sure if that would fix it. They also said that using the auto light feature is a bad idea and I should manually turn on the lights each time.
How many of you had this problem and had to install relays or that accessory harness? Anyone just install the kit and not have an issue?
Thanks
Old 10-13-09 | 05:04 PM
OneJay's Avatar
OneJay
I don't have the same HID's, but on mine, one used to turn off after a while and would come back on if I turned them off then back on. Turned out to be the ballast.
Old 10-15-09 | 09:27 AM
snook's Avatar
snook
Weird
Does anyone else think a relay or the accessory harness would fix this problem?
Problem is I can't tell when this headlight is working or not on the road, sometimes in well lit areas its hard to tell
Old 10-16-09 | 09:00 AM
snook's Avatar
snook
anyone else know what to try here
Old 10-16-09 | 09:17 AM
TheKevin's Avatar
TheKevin
CL Folding 25,000
i have 4 DDM kits. just double check all the connections. also, you can try hooking up the drivers side bulb to the passenger side ballast to see if thats the problem.
as for the relay harness, you should get one. it'll prevent your stock wiring from frying.
Old 10-16-09 | 09:39 AM
snook's Avatar
snook
All the connections are great
have you had your stock wiring on a sc300 fry from not having the accessory harness?
Old 10-19-09 | 12:57 PM
snook's Avatar
snook
ttt anyone know? ddm has a bunch of a holes for customer service
Old 10-19-09 | 01:05 PM
TheKevin's Avatar
TheKevin
CL Folding 25,000
no but it happened to my tC
Old 10-19-09 | 01:35 PM
DWPsc3's Avatar
DWPsc3
I didn't have a DDM kit but it has happened to me before. Mines ended up being a bad ballast also. So try swapping them around or replace it and see if it still does it.
Old 10-19-09 | 01:38 PM
vwynn's Avatar
vwynn
i used a relay when i had the DDM HID kit.. works 100%.
Old 10-19-09 | 01:49 PM
LAVIsH's Avatar
LAVIsH
sounds like you have a weak car battery or faulty ballast in my case both that caused that issue
Old 10-19-09 | 04:48 PM
SL3X's Avatar
SL3X
lol i got the same problem, ddm hid, but its my driver side that goes out, i got 4 of these things (2 on the fogs) and its only the driver side. pretty new battery, switched the ballast/bulbs around, still was the same. im about to use the relay i got sittin around. see if it works. you should try your oem bulbs too see if its the car wiring itself, doubt it though, probably just needs the relay, if not i got no clue lol. il let you know if the relay does it though.
Old 10-19-09 | 10:58 PM
danchon's Avatar
danchon
I'm using the ddm tuning hid kit as well. plug and play harness, no problems. a relay with a 35w kit is overkill. i will say that most likely it is a faulty ballast. For paying $60 with a lifetime guarantee I dont expect these things to be bulletproof. I bought a 4500k kit but already one of the bulbs has turned 6000k (mismatching bulbs). I called customer service and they sent me a replacement set no questions asked...
Old 10-19-09 | 11:12 PM
snook's Avatar
snook
I have the 55w kit I believe, it was the more expensive and not using a relay.
Stock bulbs work perfect, battery is brand new
I hate to have to buy one of their harnesses or do a relay for this, just wanted it to be easy and work!
Old 10-19-09 | 11:16 PM
AYEmike's Avatar
AYEmike
great kit, one for low and one for fogs, been great for a year so far.
Quick Reply: DDM Headlight HID Kit Intermittent Lighting on Passenger Side
