Pads??
Pads??
How often do are u suppose to change your brake pads? normally i would change them when they start squealing but they've done that right after i replaced them before I guess that's what happens when u dont buy the right pads. anyhow one more question. I was gonna go w/ the ECB green for my front pad but they dont sell rear pads at tirerack so i was curious what kind of pads should i get for my rears and where can i find them?
If you are using the stock rotors then I highly suggest that you stick with the OEM pads. I don't know why but brakes tend to make noise when you use aftermarket pads.
When I first bought my car i had aftermarket pads on the rear (plenty of life still left) and they squealed. I had the rear pads switched with the OEM and they quit sqealing. Even the Lexus place I took it to said they have noticed that brakes on the SC tend to squeal if aftermarket pads are used with the stock rotors.
