SC- 1st Gen (1992-2000)
Can someone please type the # off of their foglight connector
Old 10-22-09, 06:12 PM
snook
snook's Avatar
Default Can someone please type the # off of their foglight connector
The connector that comes off of your 97 foglight, I believe its a female end.
It has a 4 or 5 digit number on it.
I need that number to order the connector and the male end as well.
Old 10-22-09, 08:37 PM
TroySC300
TroySC300's Avatar
http://www.sylvania.com/ConsumerProd...lacementGuide/
Old 10-22-09, 08:40 PM
snook
snook's Avatar
Thanks but you missed what Im asking
I need someone to read me the 4-5 digits on the foglight connector. The female side, preferably from a 96 foglight unless all foglight connectors are the same 92-00
Thanks
Old 10-23-09, 08:54 AM
snook
snook's Avatar
Default Anyone have a foglight laying around please help!
I need the 4-5 digit number printed on the foglights connector
I have a 96 but I believe all foglight connectors are the same 92-00
I need this to order the connectors from Lexus thanks
Old 10-23-09, 09:09 AM
95silversc
95silversc's Avatar
They are not all the same, 92-94 are compatible, 95-96 are compatible, 97-00 are also compatible. The three groups will not interchange with each other. Also this is your second thread on this, bump your old thread before making a new one.
---edit--
Id help you but some looser sent me a bumper for a 1994 and I didnt notice so my fog lights and connector are different from yours
Old 10-23-09, 09:20 AM
Kohinoor
Kohinoor's Avatar
so youre looking for just the socket (#3)?
if so, you can order it from parts.com for $13.69 each
parts.com > enter year/make/model > front lamps > fog light > socket
Old 10-23-09, 09:33 AM
snook
snook's Avatar
Hi I know its my 2nd thread on it, why does that bother you? Im sure the forum has plenty of space and I wasnt getting a reply. I needed a reply by 12 to order it and have it come in Monday at lexus, now tuesday is the earliest if I actually get the info
actually I just want the connector. What Im doing so you guys know is using the intrepid foglights, Im going to cut off the intrepid connector and put on the lexus connector so it plugs in correctly with the connector off of my car. I want to do it this way so I dont have problems with the wiring getting wet and frying or bulbs going out as it rains here a lot and that would be another pita I dont need. Gotta do it right the first time.
I actually wouldn't mind buying 97+ foglight connectors both male and female ends in case I want to switch from intrepid lights to real 97 lights at any time. Since thats what fits in my bumper now not 96 lights any more
Old 10-23-09, 09:43 AM
LexFather
Guest
Posts: n/a
Merged....
Old 10-23-09, 06:06 PM
snook
snook's Avatar
thanks I wish someone had a 97 foglight laying around
Old 10-23-09, 06:48 PM
Luxor
Luxor's Avatar
Are you talking about this part?
Old 10-23-09, 07:09 PM
snook
snook's Avatar
Is that the back of a 97 foglight?
It doesnt have a harness?
I was told I need a number stamped on the connector to order it
Old 10-24-09, 09:06 AM
Luxor
Luxor's Avatar
Yes, the pictures above are the 97+ fog light covers that seal up the fog light and bulb from behind.
So you need to order a pigtail harness for the fog light? Wish I could help you out but since I have HID, my connectors are hidden away from reach away from my fog lights.
I am sure someone here would be kind enough to reach into the bumper air duct hole and unplug the white connector from the fog light to read you the numbers.
Old 10-24-09, 09:34 AM
snook
snook's Avatar
Thanks for your help man you have been very generous!
What I want to do is put a 97 connector on my harness on the car and on the harness on the intrepid lights that I have, that way if I decide to go to real 97 lights theyll just plug right in. I want to do this now since I have my bumper off.
What is this a picture of then? Am I only going to be able to put on the connector onto the cars harness? Since the other connector is part of the foglight backing?
What is this picture of then?
Attached Thumbnails Can someone please type the # off of their foglight connector-lexus-fogconnectors.jpg
Old 10-24-09, 10:26 AM
Luxor
Luxor's Avatar
Not sure if the toyota pigtail connector will plug into the back of an Intrepid housing. But the picture above is everything you need to properly plug into the back of a 97 fog light.
You should not worry about the black housing if you are going with Intrepid fog lights. Just hold on to those until you go the 97+ fog route.
Old 10-24-09, 03:18 PM
snook
snook's Avatar
Do you also have a picture of the back of the 97 lights.
Its confusing to me without seeing that
Its not just 2 connectors it seems its 1 connector and a weird black cap with the connector mounted to it...so my idea wont work correct?
Quick Reply: Can someone please type the # off of their foglight connector
