Help! Steering column stuck!!!
I'm lost on this one here hoss.. Have you tried checking fuses, or pushing just a little on it while using the contols to lower it? Maybe its stuck?
1JZ Single SC400
Remove the top and bottom cover on the steering wheel. Make sure to turn the wheel to the left or right to see the missing bolt behind it. You will break the top part if you dont loosen it. Its on the right side. Once this is removed, look to the left on the column and remove the 3 ten mmm bolts. I believe they are 2 on bottom and one on top. You will then see the inside of the power slide. Theres a 10 mm bolt that holds the threaded washer on. See if its slid off and/or its stripped out. If it is, replace it or turn it over and use the other side of the plastic factory piece. When this happened to me, I placed a regular washer behind the plastic factory threaded one, and regreased it with new grease. Worked like a charm ever since. Hope this helps.
Lasltly, this will only work if you still hear the motor working. If not not check the fuses and relays to the steering column.
i'm gonna dabble with it tomorrow and see what happens.
has this happened to anyone else???
Askur44
10-20-19 07:29 PM
Chinorx3
02-06-19 08:34 PM
Rich27
07-26-05 08:54 PM
