Stock SC300 + 10k = ???
such low miles on that makes a great candidate for NA-T. First thing u need to do is sit down and do some searching in what you are looking for. Maintenance is a great place to start...new timing belt (usually due at 70k), water pump and front seal. Maybe throw a thicker head gasket on there while you're at it. Next work on the suspension and brakes. Plenty of setups to choose from out there. Also throw on some nice rims. Then do some research on NA-T setups. Ask yourself: how much power do u want? Do want a street machine or a power monster? Will you need to upgrade the tranny? New clutch is a must.
You have so much money, now put aside some time and RESEARCH. Use the search function here, on ClubNA-T.com, Supraforums.com, etc. Also look around in your area. Talk with guys that have turbo setups and get info from them. Talk to shops, what they recommend and what routes to go. Your biggest ally here is information. Gather as much as you can, then execute. Be patient with your decisions and let things come to you. You have all winter to search around. Get your act in gear and good luck!!
....oh and for all that advice, that will be $5000
Here is some help for research.
note that not all of it is engine parts... I wanted a more modern look.
Code:
Costs Part Brand Criteria Sub 77 ABS Delete Kit Rocket Racing Engine Bay Brakes 31 Brake Fittings and Line Advance Auto Parts Engine Bay Brakes 12 Caliper Banjo Bolts Earls Engine Bay Brakes 256 Intercooler and piping CXRacing Engine Bay Cooling 78 Intercooler piping welded Rocket Racing Engine Bay Cooling 75 (2)16” Radiator Fans Wysco Engine Bay Cooling 26 3652 Dual Fan Controller Hayden Automotive Engine Bay Cooling 41 Upper Radiator Pipe Zerotek Engine Bay Cooling 38 Power Steering Cooler Derale Engine Bay Cooling 165 Supercooler Oil Cooler B&M Engine Bay Cooling 240 Aluminum Radiator Mitsumoto Engine Bay Cooling 52 Coolant Reservoir OBX-R Engine Bay Cooling 1540 Aristo 2JZGTE OEM Engine Bay Drivetrain 20 Valve Cover Hoses OEM Engine Bay Drivetrain 32 Acless Sryptiene Belt Driftmotion Engine Bay Drivetrain 89 SC400 Driveshaft OEM Engine Bay Drivetrain 20 Oil Pan Tap Rocket Racing Engine Bay Drivetrain 111 Water pump Assembly OEM Engine Bay Drivetrain 715 Wiring Harness Adapted Phoenix Tuning Engine Bay Drivetrain 120 Wiring Harness Repair Phoenix Tuning Engine Bay Drivetrain 78 IM and UB D&T Rocket Racing Engine Bay Drivetrain 60 Supra TT Throttle Cable OEM Engine Bay Drivetrain 80 Oil Line Kit n/a Engine Bay Drivetrain 18 Crankcase Breather K&N Engine Bay Drivetrain 87 Tru-Time Cam Gears AEM Engine Bay Drivetrain 90 PS and Alt Pulleys Unorthodox Engine Bay Drivetrain 70 Ultra Mounts Creative Steel Engine Bay Drivetrain 60 th350 transmission OEM Engine Bay Drivetrain 190 powerglide adaptor RMR Engine Bay Drivetrain 600 Flexplate Adapter RMR? Engine Bay Drivetrain 236 4” V-Band Downpipe and Midpipe Engine Bay Drivetrain 50 0 Gauge Power Wire n/a Engine Bay Electronics 35 2 Gauge Ground Wire Advance Auto Parts Engine Bay Electronics 8 1/0 Gauge Gold Terminals n/a Engine Bay Electronics 27 0 Gauge Wire Stinger Engine Bay Electronics 60 UEGO o2 Sensor Bosch Engine Bay Electronics 340 44mm Wastegate Tial Engine Bay Exhaust 150 DP and Tial Manifold Mods Rocket Racing Engine Bay Exhaust 423 SuperDrager Exhaust HKS Engine Bay Exhaust 50 Exhaust Wrap Dei Engine Bay Exhaust 11 Exhaust Ties Dei Engine Bay Exhaust 75 Manifold and Oil Fitting Mods Rocket Racing Engine Bay Fittings 15 Block Oil Pressure Fitting n/a Engine Bay Fittings 9 -3an to -3an female Fitting n/a Engine Bay Fittings 25 Fittings n/a Engine Bay Fittings 81 Line Lock and Fittings Summit Racing Engine Bay Fittings 48 is300 UB and TT BB Fitting OEM Engine Bay Fittings 17 UEGO and Coolant Bunges Summit Racing Engine Bay Fittings 99 255lph Fuel Pump Walbro Engine Bay Fuel System 80 Second 255lph Fuel Pump Walbro Engine Bay Fuel System 210 50mm Blow Off Valve Tial Engine Bay Intake 4 BOV Line Advance Auto Parts Engine Bay Intake 100 HKS Engine Bay Intake 15 Gsport Vacuum Line Kit Mr Gasket Engine Bay Intake 480 Kit RaceOnUsa Exterior Body 800 Kit Paint Perfection Autobody Exterior Body 265 Soarer Headlights OEM Exterior Body 320 Wide Fenders Origin Exterior Body 275 Fenders Paint Perfection Autobody Exterior Body 20 License Plate Frame 101purpose Exterior Body 14 2x Metallic Graphite Rim Paint Duplicolur Exterior Body 39 Battery Disconnect Switch Morso Exterior Electronics 18 Remote Battery Terminals Summit Racing Exterior Electronics 30 Taillight Tint VHT Niteshade Exterior Lighting 125 9000k HID Plug and Play Kit Onex Exterior Lighting 7 4x T11 City and Door Lights Hong Kong Exterior Lighting 9 2x T15 License Plate Lights Hong Kong Exterior Lighting 6 2x T25 Reverse Lights Hong Kong Exterior Lighting 24 2x 68 SMD Hi-Beams Hong Kong Exterior Lighting 10 better city lights Hong Kong Exterior Lighting 210 Type-S Lowering Springs Tein Exterior Suspension 37 Wheel Spacers .5” n/a Exterior Suspension 269 Center console and Dash OEM Interior Dash 0 48184 Battery Box Taylor Cable Interior Electronics 65 UEGO Wideband AEM Interior Electronics 25 UEGO Wideband Cables AEM Interior Electronics 2 2x T5 Interior Floor Lights Hong Kong Interior Lighting 16 2x 6 SMD Dome Lights Hong Kong Interior Lighting 10 12 SMD Dome Light Hong Kong Interior Lighting 6 2x T10 SMD Gauge Lights Hong Kong Interior Lighting 3 2x T11 Side Marker Lights Hong Kong Interior Lighting 700 s372 Turbocharger Borg Warner Engine Bay Drivetrain 61 RU-3040 (12”h 7.5”w 6”inlet) K&N Engine Bay Drivetrain 147 Divided T4 Manifold Engine Bay Drivetrain
Get your self a set of supra TT wheels some supra TT coilovers and a complete NA-T turbo kit with a midsized turbo and your set. I don't see the point in putting more into the wheels and suspention than the car is worth.
and is that silver spruce?
I think NA-T and a R154 with a good clutch.
NA-T:
Turbo kit, Fuel upgrades (pumps, injectors),exhaust, cams, Piggy back or full ems, rods, pistons, hg, and all the other things you need to make it work.
R154:
MKIII to keep cost down and rebuild it with some MC parts.
That alone should be a bit less then 10k with smart shopping and if you are doing the work yourself. If you don't want/can't do the work it will cost you more but a lot can be done with the 10k.
A lot of the maintenance can be done when going N/A and would be the smart thing to do. It's just your call on that one.
I wouldn't worry too much about looks when you can get a great stock looking car to avoid the cops. Wheels can help and hurt you... many people over look the extra weight or cheap out on the tires and get about the same traction as stock. Being that you also got the 5 speed an longer geared differential would help you stay in boost longer and make it a highway beast too. Remember with most of this work you are thinking of doing you might want to consider that you will also have some down time on the car. If you have any questions or help gathering some parts just PM and I'll see what I can help you with.
NA-T:
R154:
