ttempt at homemade front lip
#33
Thanks for the comments guys...I will try to do a DIY when time permits. I will also try to find a better way to mount it so that the rubber piece wouldn't tear if you grind it on cement...as I've noticed on mine. I might wrap it with fiberglass sheets to secure it or just L brackets for the center to mount/hang. The other issue is that with OEM lip there is a piece that wraps around or cover the trim by the wheel well and I am currently thinking of someways to improve this lip to mimic the original one.. Again, i appreciate all the support
