vibration at about 30MPH
I get a vibration at about 30MPH I think when the car shifts from 2nd to 3rd. It only lasts for about a second and doesn't happen every time it shifts, any ideas on what it could be?
Yes, this is very likely to be the torque converter not locking up and slipping or turbulating. Take a close look at the RPMs. This usually happens at 40MPH exactly and shows up when under slow accelleration when going up an incline. I personnally have not has this problem but it was explained to me by my Lexus service manager. The early sc400's apparently had this problem as well as the LS400's. It commonly showed up on inclined highway entrance ramps. It was described to me as a rumble noise or feeling like your rear wheels are on a washboard. I do not know what the fix for this is. I am sure a local Lexus dealer service manager can fill you in on this. Check it out.
hmm, very interesting, i happened to get that this morning.
i was going on a slight hill. and i was in 4th gear and i felt my wheel vibrating, i didnt think too much of it but a bit of my mind thought of this board and remember reading this post...
now that i re-read it, it's the same thing i experienced too
I had the same thing, what I did was changed 2L of burnt fluid out. It went away immediately. The ATF in the SC400 needs to be changed every 15,000 miles. Most people don't do that, so you'll see this problem often.
here's a link to a little semi-how to a posted.
https://www.clublexus.com/forums/sho...threadid=45980
Keep us posted.
John
Keep us posted.
John
Get this ******!!
I called the parts guy at the dealer for the type IV ATF fluid, 30 bucks, cool. So I told him to connect me with service so I could ask them how much to change the fluid. The guy told me it would be $200!! I said that's nuts! Th Fluid costs 30 and your just changing it? He said 'yep, those cars are expensive'...whatever...I'll pick it up and do it myself.
So far Carson Toyota sold me the 4L can for ~$20 each. If anyone can get it at a cheaper price let us know.
Carson Toyota 800-908-6968 Ask for Steve or Gordon
Carson Toyota is in Los Angeles near the airport close to 405 I think.
Steve Ganz is a member of this forum, his forum name is "SUPRATRD".
-Steve Ganz
-CarsonToyota/Lexus Parts
-TRD/L-Tuned
-gonzo4u@earthlink.net
-1-800-908-6968
There are a few more place (dealer) that you can buy at a cheaper price. I just do't remember of hand
Check some of the post on LS400 forum, I remember someone post the name and phone no. of a dealer in TX.
-Steve Ganz
-TRD/L-Tuned
-1-800-908-6968
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I looked it up- it's a bit south of LAX, right on the 405 between the Harbor 110 and Long Beach 710 freeways. In the center of the attached pic.
I have not changed my trans fluid in 5 years and 30K miles, so I guess I should get started. I'd hate to contaminate the old fluid with new, though. Will I get more old fluid out if I drop the pan?
Dropping the pan is uncharted territory for me. Will I need any other part besides a new gasket?
And VQT- doesn't it cost a bit to ship a gallon of trans fluid from Carson, California to Fairless Hills, Pennsylvania?
PERRYinLA,
It was free shipping at those times. They started charging shipping fee ~Nov-01 on
I ordered a bunch of stuff along with the trans. fluid at those times. Since I found out that it cost everyone $30 a can
, I ordered a can each times I ordered parts from Carson. So far, I used up 3 cans already. I haven't took the pan out yet. I don't want to create more problem than what I am facing now. I need my SC to run everyday. (my Vette is down for the last 6 months
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
VQT, u used 3 cans already?!?!?!?
just how frequently should u change it? and wat exactly is ATF ? are we talkin about tranmission fluid here? i have a manual trans. what should i use?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I bought two SC400 last year. Both develop the rumble after I bought the car. The white had the rumble for at least 5 months before I changed the ATF. I should of replace the ATF by dropping the oil pan because I had to drain the ATF within 4K mi. to get the rumble completely gone. That's more than one can already...
Then the green SC develop the same symptom...
I am too lazy to drop the pan to change most of the ATF, so I just drain 2 liters at a times. To fill the ATF after the pan will take 8.1 liters.
quote:
______________________________________
"To fill the ATF after the pan will take 8.1 liters."
Sorry to beat a dead horse here, VQT, but I thought about 1/2 to 1/3 of the trans fluid is "stuck" in the torque converter and won't drain out, even with a pan drop.
I don't think anyone would need or use those $150 "flushing" services if you could drain all of the 8.2 L of trans fluid by dropping the pan.
But I've never done it, and you have- so I just wanna confirm how much of Type IV to buy if I intend to drop the pan. I'll be using ramps, so the car will be tilted, and I don't mind waiting overnight if it will all drain out eventually (guess I should do this with the fluid warm, right?).
Thanks for all the informative posts!
The manual also read the Toyota Type T-II (T-IV now) help smooth out the shift (changing grear). It didn't read that you have to use Toyota Type T-II. It read type T-II or equivalent. I don't know of any after market ATF that comparable.
