SC- 1st Gen (1992-2000)
Volks progressive TS 20's on my sc400
Old 10-29-09, 05:36 PM
Gotboost24
Gotboost24's Avatar
Question Volks progressive TS 20's on my sc400
Hey guys having a tire fitting issue not sure what tire to run. The are 20x9.5 in the front and 20x10.5 in the rear. Maybe some one has done this maybe not love some feed back and suggestions. I gotta great price for em so I had to get em now to just gettem to not rub or ridiculously stretch the tire. Thanks guys!
Old 10-29-09, 06:11 PM
GS FONZy
GS FONZy's Avatar
There are a few things you must mention inorder to get help. What's the offset of your wheels? Are you lowered, how much, coils, etc..?
Old 10-29-09, 06:44 PM
GZZ-TT
GZZ-TT's Avatar
Check Scotts setup and just mildly change it depending on taste, and the tiny size difference.*
https://www.clublexus.com/forums/sc-...c400-pics.html
I've always wanted to see those mounted on an SC, so plz post up pix after install.
Old 10-29-09, 06:55 PM
96SC4
96SC4's Avatar
haha,,,i always said 20" is too much...but Scott's car looks juuuust right.
Do it OP...!! can't wait to see 'em
Old 10-29-09, 08:23 PM
Gotboost24
Gotboost24's Avatar
Front is +23 rear is +24
car is stock height at the moment but i'm planning coilovers once tires are figured out.
Thanks for the rapid response fellas
Old 10-29-09, 10:13 PM
GS FONZy
GS FONZy's Avatar
No way in hell those will fit without fender work. Shave/roll and stretched tires will be required, maybe even some camber.
Old 10-29-09, 11:01 PM
Gotboost24
Gotboost24's Avatar
So I'm lookin at a wide body kit.. Or sell em off for $2500 they're brand new if anyone is interested. The wide body would work out right?
Old 10-30-09, 07:10 AM
TheRonTom3
TheRonTom3's Avatar
no. wide body would be too much and require spacers. maybe orgin front fenders but i still think those would be too much and leave an ugly gap unless you plan on running low enough to be tucking a little rim
roll your fenders.
stretch your tires
run some camber and possibly do a newspaper pull in the rear
Old 10-30-09, 09:25 AM
Gotboost24
Gotboost24's Avatar
Should I roll the fenders or pull?? After newspaper pull is done what's my best bet tire? Or should I sell them to a 350z or g35 guy. I appreciate the help
Old 10-30-09, 09:43 AM
t70 supra
t70 supra's Avatar
im running 18x10 f and r here still trying to figure out my offsets
Old 10-30-09, 11:03 AM
TheRonTom3
TheRonTom3's Avatar
1. test fit wheels on the car at ride height you want and camber you want using jacks and block with towels on them under the wheels to protect the wheel. This whill allow you to see how much the wheel will camber in as well as how much room you have for your tire.
2. Find tires to fit what you just found out.
3. roll fender lips flat
4. depending on what finding you have from step one here you will either pull your fenders or newspaper pull your fenders. A newspaper pull is done after the tires are on the wheels and the wheels are on the car just to clearance the fender a few mm away from the tires so it does not rub while normally driving (NOTE: a newspaper pull will still rub under accelleration and with more than the normal weight load in the car unless you are running alot of camber)
Old 10-30-09, 03:34 PM
GS FONZy
GS FONZy's Avatar
Are you looking for some meat or rubberband? How low do you plan to go?
Do you have a body kit, lip kit, etc...?
Old 10-30-09, 04:28 PM
5sp_jzz30
5sp_jzz30's Avatar
9.5+23 you can run 255/30 all day or w/e there is available.
10.5+24 you should run a 245 or 255. nothing less then that. you will need to roll the rears completely. do at least 2.5* camber. also a solid 2-8 inch drop is in order lol jk
to make the rears fit nicely just slam the crap out of your car and do a minor pull.
these wheels will never fit on stock ride height.
they will stick out more then the "amigos that come to chill in front of walmart"
Old 10-30-09, 10:21 PM
Gotboost24
Gotboost24's Avatar
I would love to run these wheels I will run coilovers to drop the *** out of the back. The 275/35/20 rubbed barely should I run coilovers, 275/30/20 in rear and 255/30/20 up front and fender pull as neccessary in rear along withe newspaper pull.. Input on this senario?? Thanks fellas cross my fingers I can deal with thin tire just not cut rash city you know?!?!
Old 10-31-09, 02:07 PM
GS FONZy
GS FONZy's Avatar
275/35/20 is way too big for the SC. You need a good stretch too, so I would not go wider than a 255 in the rear, unless you want to pull your fenders. Also, if you don't have a kit or a 97+ SC, 20's won't look good. Just a thought.
Quick Reply: Volks progressive TS 20's on my sc400
