Need Help with Door and Fender
So im gonna tackle taking off my passenger door to fix it and try to get it open but in need to know how many bolts are holding up the fender i know theirs 3 on top anny under the sideskirt? and tricks to get a front bumper off..
thanks
thanks
Two on the bottom of the fender near the sideskirt. Usually covered in the factory undercoating. If I can remember there are one or two near the hinge on the door. There is a pin to line up the door so noo need to worry about alignment.
Remove the inner fender liner first so you can see all the bolts holding the front bumper on. You'll have to remove the headlight first. Make sure to put some tape on the bumper in front of the headlight so you don't scratch the bumper when removing the headlight. shouldn't have to take the bumper completely off to pull the fender, just enough so you can unhook it for the fender.
