How do you remove the Center Console?
The whole center area that goes down to the carpet and that the radip bezel and center console storage are attached to.
Are there instructions on this anywhere?
Thanks
Thanks
remove the cup holder in the middle.. by pulling up on it..
pop off the shifter bezel .. after you take off shift ****.. remove those parts ..
remove a few screws from under the cup holder and shifter bezel..
now take off the center counsel trim...
inside the arm rest .. pop off the little round caps.. screws under there.. and theres a fake bottom to the center arm rest. take that off.. 3 screws under there..
there are 2 screws one on each side at the corner near the gas pedal.. and other side as well..
then i think it should come up.. im sure im missing a few screws .. but.. if you pull on it.. fallow it to wear its not budging.. and unscrew it..
i know its bad directions .. but i hope this helps..
Neu`roc´i`ty
Search Tab comes up with this...
There are some links that are Dash removal but read into them and you will find how to remove the Center too.
https://www.clublexus.com/forums/sc-...e-removal.html
https://www.clublexus.com/forums/sc-...wood-trim.html
https://www.clublexus.com/forums/sc-...n-removal.html
https://www.clublexus.com/forums/sc-...d-threads.html
