window metal piece that holds glass to track
the little metal end cap (you can see it in the top corner when window is closed) that holds the window glass broke off so now i have wind noise and the window has trouble moving... anyone else experience this? is there a fix or do i just need to replace the glass
just wanna say i found out that the piece i am talking about is the glass guide roller which i just found. i have a few from a previously broken window so i have to remove the glass and reinstall it into the guide rail with the new roller washer and nut... just fyi if anyone else has this happen..
mine must have popped off and broke from pressure due to misaligned window rails.. now this will give me a chance to get into the door and make all necessary adjustments to prevent future problems
