Just a few questions for you all knowing peoples!
Whats up all, I am new to this forum and I will be honest I haven't even looked through them too much. So I am sure that the answers to my questions could be out there in these forums, but whats the harm of having the answers come to you.
Quick info about my SC3: 1995 3.0 I6 2JZ-GE- Auto/Trans. STOCK!
So on with the questions:
Q: What aftermarket brand of coil-overs work best for the SC300?
Q: Is Cusco brand a good quality front upper sway bar?
Q: With budget in mind, (not ebay brand), what is the best turbo kit that you recommend for the 2JZ-GE-? (Obviously TT would be awesome, but I am asking about brand quality)
Q: I know many exhaust brands, which brand would you prefer, with performance, sound, and budget in mind?
Q: I will be doing a 5speed conversion, W58 or R154?
Q: Isn't the R154 tranny paired with the 7mgte, if so will it work bolted up to the 2JZ-GE? Possibly needing the 2JZ bellhousing?
Q: During the 5speed conversion, will the ECU have to be swapped with a manual programed ECU?
Q: Has anyone seen an "Army Vehicle" color and build themed SC? (example: Flat OD green paint, white star on side, stenciled letters and numbers, stripped interior with "****-pit" vibe)
((No links, kinda spammy looking))
Thanks to all that may answer any of these questions, haters keep it to yourself! Thanks
I say this cause I'm a haters...Iz hates tha lazy peoples!
Here ya go...
https://www.clublexus.com/forums/search.php?f=6
You write in search words (key words to things you are looking for) on the left.
Then choose a section you would like the search bot to search in. (This narrows it down significantly)
Then hit "Search Now". It works, I swear! Try it!
Depends on what you want. Stance makes some good coilovers.
No clue.
Depends on your budget. You didn't state if it was high or low. XS power makes a decent cheap and reliable turbo setup.
Flowmaster or magnaflow are good. Alot of people here rock Blitz Nur Spec's or Apexi World sports.
Are you keeping the 2jz-ge? If so your w58 is just fine. If your boosting, change your clutch and so on. Stock clutch will slip.
Not a clue.
You don't need to use a manual ecu if all your doing is auto to manual swap. Search "auto to manual" and you'll find out what needs to be done.
Naaaa
No clue.
Not a clue.
Naaaa
MiataMatt
SC- 1st Gen (1992-2000)
03-27-14 10:57 AM
empera
SC400 / 300 Classifieds
12
10-11-10 12:52 PM
