drilled/slotted rotors
im getting my rotors for $350 all four from lexusSC400.com he is supposed to have them tomorrow, ill let you guys know how i like the rotors, and the service when i get them.
on the raybestos i tried them on my LS400, and i didnt like them, the OEM pads where quieter, stopped better, and made less dust.
OH and the raybestos also gave my LS rotors hot spots. i had the raybestos on the integra and had the same problems, never knew it was the pads
just my experience, to each is own.
Xavier
Xavier
I got my rotors lastnight from lexusSC400.com and i put the rear rotors on today (ill put the front ones when i get rims) i only put the rear ones because one stock rear rotor was cracked.
so no complaints from lexusSC400.com
Xavier
Xavier
Guest
Posts: n/a
I have cross drilled on my 1990 LS and I replaced my orignal stock WARPED rotors so I can't compare the difference between good stock and the cross drilled.
Although I noticed that my cross drilled are much more cooler after long periods of driving and high speed braking. They are a bit more noisy, and I think they are eating my pads quicker.
The cooling is the biggest difference that I've noticed.
yea there bradi rotors, ill let you guys know what i think of them after i put a few hundred miles, but sofar i havent had any problems, i have them on the rear only, ill put the front ones on when i need new pads, im lazy right now.
but sofar for the price at LEXUSSC400.com you cant go wrong.
