how much did it cost and where in fl u located see if i can get my interior done to ahaha pm me
Sent you a pm about more info
Originally Posted by BLK13X
Looks nice
I'm doing a black/tan combo on one of my Soarers as well (although it'll be given away pretty soon )
Thank you very much I'm equally as sad to hear your working on it yet won't be able to enjoy it Good luck with the project though!!!
Originally Posted by ScottURnot
Black tan FTW! Nice job!
Thanks a lot Scott!!! Your petty much the main reason why I went this route. Once I saw your black/tan interior when I first joined this forum I knew I wanted something similar in my DWP SC. Keep up the great work on your SC
Originally Posted by lexusB3
dammm looks maddd clean to me i like it thinking about doing the same put black starting from the bottom
Appreciate the kind words I think the black starting from the bottom would be a good look. You should definitely go for it!!!
I think it would look better if you colored the faux wood as well. Three different colors is too much for me but I appreciate the work you put into it.
Haha...thank you as always for the kind words Scott
You know I would not mind coloring it but I have yet to come up with a solution to that problem. I don't want to go with white nor solid black. The only real solution would be what Scott did and go with a black burl wood he has but that is a little bit out of my money range at this point
I agree I would like just a 2 tone for the interior but this will have to do for now. I appreciate the comment though
Looks beautiful, I'm diggin the woodgrain. is that oem or aftermarket? (woodgrain)
Gracias for the comment If you are referring to the woodgrain where the shifter, cupholder, and window switches are located than those would be aftermarket. All the rest of the woodgrain in the car is from the factory. I like the wood in the car since it brings in that luxury aspect a little
