SC3 Spec. & Info.
SC3 Spec. & Info.
Hi all,
I am looking at the SC300. Is there anywhere I can find info. on this car such as spec, preformance, engine, and other related info.
It is difficult to search all the stuff around.
Also, I want to know what engine it has. Does ALL SC3 uses 2JZ-GE engine?
a supra guy hu? Yes, all Toyota JZZ31 Soarers (Aka the SC300) come with the 2JZ-GE
3.0L in-line 6
225hp, 220 lb-ft torque
0-60mph 7.9sec
4-speed automatic Electronically
Controlled Transmission w/intelligence (ECT-i)
Fuel consumption: 19/24mgh (city/highway)
Available from 92-97 in 5sp (same 5 speed as in the MKIV N/A Supra)
John
3.0L in-line 6
0-60mph 7.9sec
John
SupraCoup3,
Thanks for your infomatiive reply. That's mostly what I want.
I still have question left.
Is there any changes ( interior, exterior and performance) through 92 to current models? I just know that the tail lights are different compare to the most current model.
How would you all compare to a N/A Supra?
Thanks,
Thanks,
Here's a link to all the changes in the SC400. http://www.intellexual.net/sc400frames.html . The SC300 has all the same cosmetic changes as the SC400, so just ignore all the engine and performance changes you see. SC300 is a luxo Supra NA---smoother, quieter, (heavier) ride.
Thanks a lot to everyone. That's exactly what I want.
BTW, I was expecting the SC4 has 300+ hp. If the SC4 as only 35hp more, wouldn't it be better off to get a SC3 instead? Just a thought.
