Finally sporting a 24 LED 5 speed cluster to match my 5 speed conversion!
#121
So a couple months later, a couple of these LED's burnt out.
Im not too happy with the fitment, and the whole setup with all the hotspots and what not, so i decided to go with the angel eye method. It seems like a win win scenario.
For those who dont know, heres the thread:
https://www.clublexus.com/forums/sc-...plication.html
#122
#126
Hey Mike,
No it doesn't fix the needles. If you look on page one for a posting from O.L.T. he has a web site with some very cool specialized instrument cluster illumination. Included in that, he can fix your instrument needles in any colour you want.
#127
The LED's I used are still on ebay.
EBAY LINK
There is exactly 1 inch of clearance inside the cluster.
EBAY LINK
SuperbrightLEDs has some cool looking replacement bulbs, but I suspect they might lead to hot spots. Ideally I'd like to try green but don't want to find the display is too dim. Since they're expensive I'm reluctant to do much experimenting. I'll leave that for the more well heeled members of the forum.
I guess it could start to look a bit awful with LEDs from different sources being different colours.
#129
He's also 10x the pay... or more.
#130
EBAY LINK
EBAY LINK
http://www.superbrightleds.com/cgi-b...ge.html%23wled
If I understand the problem correctly, the hot spot is created because the LED used had a single light source shining directly at the back of the instrument panel.
These lamps appear to address that problem with LEDs aimed in a radial manner parallel to the face of the instrument. This should provide lighting more like a tungsten lamp. Does anyone know how they compare in brightness with a conventional 194 bulb?
#132
im new to this site and forum. but i wanted to know if anybody knows about replacing needle lights. please send info if you do.
also, these lights can be bought from ebay and installed fairly easily, correct?
#133
There's only one dude doing the needles AKAIK. He goes by O.L.T. There are some DIY's out there for just having the needle tips light up. Search burnt needles.
Yeah, the ebay LED's are cheap and easy. Some have had poor results with failures, but mine still work perfect - too bad the rest of my car doesn't.
