Sc's with 19 g35 rays
#46
Yeah, there is enough room inward with stiffer suspension. With the 265r I was running, there was a barely a mm clearance to the plastic piece. Didn't know removing it would allow 275s. Either way, I think 275's are too fat for the rim visually. This is all with stock offsets.
#47
Here's a good calculator:
http://www.1010tires.com/TireSizeCal...?action=submit
Factory size is 225/55/16 - you can see how several different sizes compare.
#52
#59
A good all round tire for cruising and city driving. Stock suggests front and rears be 225/40/19 and 245/40/19 I think. Although how much worse would the comfort be with 245/35s?
I'd also love to know how the wheel sits and whether spacers are required, or fenders rolled for the stock tires.
#60
In regards to tire and ride quality, well, that's always subjective. Generally speaking the lower the height the rougher the ride. If it was me though, I'd look at running a square setup and go with a 245/35 or 245/40 all around. This gives better handling and will allow you to rotate your tires resulting in longer life.
