Trunk wont open
FIXED: problem with only having valet key and a locked trunk release.
if you pull off the bottom section of the dash where the lock it, there is a clip surrounding the bottom of the lock, closed to the exterior of the dash, pull it off, and there will be a slider, push it in and move it to the left (toward the unlock side as if you had the key in), the lock will release and the trunk will then open. Took me ten minutes
