SC- 1st Gen (1992-2000)
Gear Oil Leakage?
Old 05-11-02, 10:03 PM
MrGQ
MrGQ's Avatar
Default Gear Oil Leakage?
Okay,
So I was changing the engine oil on my '93 sc300 today and noticed that this center block in the rear of the car is covered with gear oil. I don't know what you call the part, but it sits in the center rear of the car, where the two drive axiles and the crank come together. I'm guessing that maybe a gasket must have gone bad. Has anyone seen this problem occurs to their SC? Do I need to be worry and fix it imediately? If so, what's the most cost effective way to fix it? Thanks in advance
-MrGQ
Old 05-11-02, 10:46 PM
Toan Nguyen
Toan Nguyen's Avatar
Default That would be the diff?
Differential?
Old 05-12-02, 07:41 AM
SCV8
SCV8's Avatar
I had the same oil action back there,I checked the level,and it was fine.Afterwards I cleaned the mess off of the bottom of the trunk,and differential housing so I could better see where the leak was,but it hasn't returned in over a month.I just figured the dealer over-filled it when they worked on it.
Old 05-12-02, 03:53 PM
Pearlpower
Pearlpower's Avatar
Default common
The differential leakage is a common issue with the SC's. What is required is a drain of fluid, pop off the cover and rebead with orange gasket maker.
Gasket maker-$4.00=Permatex red/orange
Good synthetic fluid 2 qts-$7.50
total cost -under $10.00.
Labor- under 30 minutes
Old 05-13-02, 09:11 PM
MrGQ
MrGQ's Avatar
Thanks for the replies everyone,
So, can I get the gasket maker and synthetic fluid at any regular auto store or do I have to get it at the lexus dealer? Also, I'm thinking of doing this myself. Will I need a torque wrench for this?
-MrGQ
mfdif
09-24-18 09:11 AM
Hacc
13
06-09-17 08:09 AM
Bocatrip
03-15-17 11:40 AM
durtysc300
Performance & Maintenance
04-27-10 04:38 PM
TouringGS
Performance
02-08-04 12:46 PM
Quick Reply: Gear Oil Leakage?
