Christmas present! what adaptor kit?
Hey guys, i got a new head unit from santa! its got a 3in LCD screen i believe they call this a single DIN. now, tomorrow when i go to best buy to buy the installation kit with the little shelf and stuff, can i get just a toyota one? cause i've seen/ heard that SC's are PITA when it comes to this.
also, i'm doin this myself, so to install a new deck, do i need to start at the cup holder and take out the whole center console, or does the stock nak just pop out?
merry christmas to everyone!
not sure about the correct adaptor kit but i know you gota take the trim around the stereo out.
start at the cup holder, just pull that straight up and out, then start to pry it all out. where the cigerette lighter is, pop the cover open to start to pull that out as well. make sure you dont RIP the whole thing out because there are wires by the shifter and for the any button on the center console. its really easy and takes maybe 5 minutes.
Remove shift plate and then cup holder by the arm rest. Remove all screws, then pop out the center trim from the cup older end. Remove plugs to get it out the way, etc... I am sure there are DIY on this already. Also, I doubt any toyota stuff will fit. I got all the stuff from ebay and it worked great. The metra kit is not the best, but it works! GL.
heres a couple threads for yah
https://www.clublexus.com/forums/lex...b-working.html
https://www.clublexus.com/forums/lex...c-92-00-a.html
https://www.clublexus.com/forums/lex...ead-units.html
and i install for bestbuy and we dont stock the kit for the scX00 so you might want to call your local store and ask before you drive down there
and i install for bestbuy and we dont stock the kit for the scX00 so you might want to call your local store and ask before you drive down there![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
wow, thank you guys tremendously, those links are invaluable to my buddy and i. we would have had endless troubles with it, i'm installing a single DIN head unit. so thank you! i'll order the metra install kit. you guys are the best!
Derek
Derek
