healight fog
healight fog
hey i my passenger side headlight n highbeam light are foggy on the inside is there a way to solve this by taking it apart cleaning it n resealing it or somthing??
NOOBS, there is a search function here on CL and I cannot stress enough times over and over that it will answer 99% of the questions you could possibly have about your SC, and any issues you may encounter and it will also help to keep the incorrect solutions from floating around on the forums.
better yet, I'll be nice and give you the links on how to solve the issue..but next time, search.
https://www.clublexus.com/forums/sc-...finishing.html
https://www.clublexus.com/forums/sc-...headlight.html
no problem..wasnt trying to sound like an a**..just be sure when you put your headlights in the oven, place them on a cookie sheet on the middle rack. This will keep the softer plastic on the bottom from warping. also, before you reseal them, grab some silica packs and stick them between the main housing behind the chrome, reseal with 100% silicone and let it cure for atleast 12 hours.
