Bought some parts ... need some help. Please look.
I have been having some problems with the idle on my SC4 and bought some used IACVs on-line. I received them and was surprised to find two different part numbers (versions) of IACVs (left = 22270-50020, right = 22270-50010): (FIXED)
http://s951.photobucket.com/albums/a...s.jpg&newest=1
The IACV on the right is identical to the one installed on my 1993 1UZ-FE. The left unit has a smaller stepper motor, a larger pipe on the upper left and a slightly different plate.
Can anyone help me ID the unit on the left? What model does the IACV go to?
Thanks ...
Thanks ...
The one pictured on the left with part number 22279-50020 does not match anything under Lexus or Toyota. Is the 5th digit supposed to be a "9" or a "0"? If it is indeed a "0" (22270-50020), that IACV should fit 90-92 LS400/SC400. The IACV pictured on the right with part number 22270-50010 shows up for 93-94 LS400/SC400 and fits your car as you already stated. Hope this information helps a bit.
Mo,
U are correct. The part numbers are identical except for the 50010 vice 50020.
jdanielca
10-05-18 06:33 AM
boostedGS
GS - 1st Gen (1993-1997)
09-06-08 08:44 AM
