Chassis harness clip removal
To those of you who have relocated your wiring harness by means of unclipping it from the drivers side panel- how did you pull the clips out? I've tried needle nosed pliars, prying off with a flat head screwdriver, and of course pulling them out by hand. Anyway, I've only been able to get like 2 off and I'm stuck with the rest.
How did you guys pull them out? I've searched, and I've tried everthing I can think of. Any other suggestions?
Location: Sideways on the Yellow Brick Road! < Thats KS!
Then there is this one, I love the part where Brian tells them it unplugs after they cut every single wire. LOL
https://www.clublexus.com/forums/sus...nch-v-lol.html
Does this one help?
https://www.clublexus.com/forums/sc-...e-harness.html
There is a pic of the plug deeper in that second thread.
The clips are tight but a screwdriver typically works. You really have to push the release clip in hard then push in on the plug and pull, it should come right out.
I've tried eveything from a screw driver from a eyeglasses repair kit, to a pretty beefy one.
That DIY is for a sc400, my manual sc300 has more fuses in the same space, so everything is jammed in there a lot closer together. Makes getting screwdrivers and angles a pain. I'll keep trying though.
At least I know it CAN be done, and what its done with.
Thanks guys.
Sarah
When I pulled mine, i used a very thin flat tip and inserted it deep into the connector to release. Some of the connectors latch deeper than others. Then wiggle left to right till it pulls out. I recommend taking out the driver's seat to get more leverage BTW.
I couldn't disconnect the wiper wiring harness. Since it was such a small amount of wires, I just cut it and respliced in the wheel well.
hitekexec
04-20-17 10:30 AM
