How do I fix power windows??? URGENT!!
Just bought a 1993 Lexus SC400. the power windows and moonroof not working. checked the fuses and everythings good. voltage present on the main switch, but cant identify pin numbers. came with no repair manual to trouble shoot if switches are working. can anyone help me? thanks.
what do you mean by relay box? when you press the switch, no sound comes out from thhe motor, but power door locks work. are the power door locks and the moonroof controlled by a different circuit?
My sc does the same thing its not the regulators both windows and sun roof stop working at the sametime I check the fuses and they r good if u figure out the problem please let me know what it is
The reason I said the harness is because I had this problem on my MR2. Aside from causing the windows and pwr mirrors not to work, it also caused the doors to lock themselves, caused aftermarket alarm to go off randomly, made dome light stay on, and killed the dash clock. When I fixed the harness, it fixed everything.
i'm having the same problem...smfh
both side windows used to work then slowed down and now they dont work at all... and i have the same problems both windows dont work, and my power side mirrors dont move, and my windows unlock themselves when i have the door open and use anything that takes up power.. and i'm also getting a small buzzing sound from the main switch when i press for the window to go down.. but my sun roof works perfectly
is the harness my problem for sure or is my car on some other ishh???
My 97 sc400 is suffering from the same issues (windows, sunroof, cruise, heated seats, auto headlights, shifter lock) all stopped working at the same time. Even my power steering was affected. If you ever found the root of the problem, please let me know.
