VIP Route in the works! ABC exclusive's 2 piece
got rid of my TT wheels and decided to go the VIP route on my SC300.
wheels: ABC Exclusive 2 piece
specs: F18x9 +15 offset 215/40/18
R18x10.5 +30 offset 225/40/18
definitely going to replace the 225 rear tires with something wider as 225 on a 10.5 is just a ridiculous stretch. thinking about 255 rears and just putting the 225 in the front to replace the 215s. will also add a 5MM spacer in the front and a 10MM spacer in the rear just to flush them out a bit more.
UPDATED PICTURE ON PAGE 2 with SPACERS AND MORE DROP
if you're just going for [looks] and not [performance] then keep the tires you already have in the wheels and just add the spacers/adapters, lower your car another 1" or 2" all around, and camber the rear a bit. Stance would be sick homie.
nice choice of wheel btw.
i'm not even sure 255's will fit with spacers without causing major rubs. i say keep the tires the way they are. and plus, if plus you're not vip unless you're stretching. 225 on 10.5 would be on the conservative side imo
nice wheels nonetheless!
When tires are stretched like that and the rims starts to bulge out like that it just looks ugly... It just does. Doesn't matter what rims you have. They look good from far, but not from up close. I hope you don't hit a pot hole.
