Just Joined Forum with 1992 SC400
My son just bought a 1992 SC400 with 180K miles. I hope to get some useful advise out of this club as we repair various worn out/ broken items. I don't have any history of what's been repaired on the car. Several items on our repair list for starters. I haven't yet dug through the prior posts but if you folks can answer or aim me toward prior posts I'd appreciate it. So our initial short list:
1) Hood support struts broken. I'm surprised on how heavy the hood is. Found replacements on **********, but don't want to get stuck getting getting one's that might be too flimsy. Any advise? Local parts stores don't seem to list hood struts for SC400. Do other models use the same size?
2) Trunk support struts broken. How do you remove them? Tough getting to the 12mm nut near trunk arm. Do I remove the clip on forward end 1st? How do I get this clip off?
3) Passenger door doesn't open from inside. Outside works fine. I suspect broken cable or connection from inside linkage. Any tips for what's broken & repair steps. I don't want to mess up door panel as I remove it, so pointers on that would be great.
4) Antenna mast broken. (Power antenna). Can the mast itself be replaced, & still work with power up-down, or must we change the entire power antenna?
5) Timing Belt Intact but lots of cracking. Must replace. Any other items likely to need replacement as we disassemble to get to timing belt?
6) Tune up. Got a list of parts?
7) Fuel pump makes whining noise...sometimes.
8) A/C control display 1/2 visible.
Thanks in advance for all the threads I hope this sparks. The car looks sharp with it's repainted metallic red, & seems to run pretty good. I want to take care of numerous neglected & worn out items. Looking forward to lots of good advise.
These are all common problems.
2) Trunk support struts broken. There are DIY's out there. Search
DIY
Again - SEARCH Link
There are rebuild services on ebay, or you can buy the LCD and DIY, or contact aliga here and buy a used one.
I'll let you search for the others...
DIY
Again - SEARCH Link
I think ishootstuf did a pretty good job searching your main problems and answering most of questions but
1. If they say replacement and its a reputable site it will probably work.
4. I believe the mast can just be replaced.
8. The bleeding screen over half members on here probably have that problem or have had it. But Aliga your man
Welcome. Pics of car
Velcommen! Good luck modding- get some aftermarket parts to update your sons SC!
ClubLexus Classified Ads
it's Willkommen.
1JZ Single SC400
Welcome to CL, as I have the same car..
For the hood struts, just measure them and take the measurements to Oreilys or Advanced and have them to replace them with new ones. The same for the rear also. Heres the link for replacing the rear..https://www.clublexus.com/forums/sc-...rt-w-pics.html
For the door...https://www.clublexus.com/forums/sc-...iy-w-pics.html......
For the antenna, can you hear the motor running at all?
Timing belt.. Uses this link, excellent write up...www.lexls.com.. Look under maintenance and you should find it. Its the same motor but different intake. You dont have to pull the radiator out. To get the crank pulley off, slide a 22mm over the crank bolt with a big ratchet, then slide a piece of pipe over the ratchet, then wedge the pipe under the driver side of the car frame, then BUMP then starter, DO NOT crank it.. Then will remove the crank bolt like butter. Its on there with 192 ft/lbs.
I would replace the spark plugs, air filter, caps, rotor buttons, and wires, while I was doing the water pump and thermostat. All of this will have to removed while you are in there anyway, so replace it.
Fuel pump, search on here.
Blackened LCD or climate, send it to Lextech Lighting. Contact OLT on here or Pm him for advice. You can buy just the LCD off of Ebay for around 125, then resolder it together and junk the old one, I would replace all lighting while in there. DIY is also on here.
Hope this helps you out.. Again Welcome to CL! Good luck with your car..
Thanks for the welcome & the all the prompt replies with numerous links. Lots of good info. Just moved car into the garage for it's various repairs. Doug (my 21 year old son) is dieing to get this baby on the road. I know once he does, it will be hard to take it out of commission to do much work on it. Until then, he's stuck with the '89 Ranger (which I rebuilt). Obviously the Ranger just doesn't have the WOW factor that the SC400 does.
make sure you get the correct struts for the trunk because they sell NON-spoiler trunk 92-96 struts and spoilered trunk 92-96 struts.
Trunk struts & hood struts removed. Had to heat the trunk bolts with propane torch to break the loctite. This easily did the trick. However it certainly wouldn't pass the "safety moment" checks at work. Propane torch ~ 6in away from fuel inlet pipe & ~ 1 ft away from the main gas tank. Kept waiting for the KaBoom! But seriously, I made sure no gas smell & adequate ventilation with fan flow. If I saw my son doing this I probably would have chewed him out for being unsafe. BUT do as I say, not as I do... and he didn't see me. Both hood struts & 1 trunk strut were shot.
Steelwheel
SC- 1st Gen (1992-2000)
16
02-14-08 03:42 PM
