Na-t feed lines?
Na-t feed lines?
Ok, I have bin searching and haven't came up with what im lookin for...
You Na-t guys out there running your oil feed lines, i've seen taping the union bolt by the oil filter and i have heard you can use a sandwich in between the filter.... is anyone out there using that method?
If so, what one are using? Is there something i should look for when buying one?
pics always help too
thanks
Dale
thanks
Dale
thanks
Dale
thanks
Dale
sandwich plate is for the loose just for getting oil for your turbo.
why interfere with your oil filter when you can get a dedicated line from the union bolt for your turbo.
I bought the union bolt from an IS300 from the dealer for very cheap, cheaper than a sandwich plate. It already has a hole there, no tapping was needed for me. plug and play.
I really don't see how you can beat that. you just use a 1/8 to -3AN or -4AN depending on the size of your lines and bam, no need to mess with your oil filter.
mines hasnt leaked a drop, and this method is cool cause you can use a T here and add oil sensors if you like.
please read: (just imagine it says line instead of pressure sensor)
http://www.mkiv.com/techarticles/oil...mod/index.html
I went with the sandwich plate for a couple of reasons..IF I ever decided to go back to N/A, I wouldnt have to replace the union bolt if tapped, or if I happened to lose it. Second, it has 2 auxiliary AN fittings to easily install oil pressure and temperature sensors when it comes time without having to install extra fittings.
Now as for it interfering with the oil filter or oil pressure or any other oil/mechanical related issues, never heard of any problems from people using sandwich plates, nor have I had any problems with it myself. Not saying its better or worse than tapping your union bolt, it just made sense with the convenience of having the extra outlets for oil related gauges later on, and it took less than 5min to install it, and like I said, IF I ever decide to go back to N/A, remove it, plug the pan and Im done.
Its personal choice really..spend a little more, and have something easy to install that doesn't require extra fittings for gauges, or spend less for the union bolt, and a few cents more for a "T" fitting for gauges..neither will interfere with oil pressure, or your oil filter or oil changes for that matter..its just $50 vs. $20(?) for the union bolt..
even though i'm not turbo'd yet, i'm using it as a oil pressure for now and when i am turbo, i'll use the other holes for an oil feed for the turbo. i bought mines for like $30 or so from here http://www.glowshiftdirect.com/Oil-F...-Adapters.aspx
same exact one I am using..just seems to be cheaper there than ebay.
no problem.
Sup Dale, I see that you are getting that boost itch now huh? I know Chris ( turbodremz) used a sandwich plate for his NA-T project and he said it works perfectly fine. I believed he said he got it for around 50 bucks or so, you can PM him for more details. I am still looking for Stance coilovers then I will be prepared to order that motor.
Anywho.. great info guys! Im taking both into consideration not sure yet but i have time to decide because im poor..
Whats up man, ya Im gettin it like a kid gettin chicken pocks haha, but ya im trying to gather alot of info and plan it out lil more as i get money, with being a little over 100k i think ill be ok and ya i want boost im sick of being slow haha
i drilled and taped mine, very easy. taped 1/8 thread to a -4 an feed. then just put a -4 on the turbo. bam done. if you ever go back to NA you can just buy a 1/8 plug and plug the hole
ptetra
CT 200h Model (2011-2017)
13
10-02-22 06:59 AM
99custom
02-25-18 07:54 AM
Pheonix
03-15-06 02:42 AM
