Putting the stock seatbelt on racing seats..
Hey everyone, i have a bit of a dilema and need a little help. I recently bought some Bride DIGO seats for my Sc300, and currently in the process of fabricating seat rails that will bolt up to my Sc. In the process i realized that the seatbelt is actually attached to the seat and ran through a wiring harness under the seat. Trialing the wires up the harness i found that the wire from the actual seatbelt(brown w/ 2 silver dots) splices and goes into another connector on the seat. Then splices again into 4 more wires. I realize that these seatbelts are a special kindof unit as you can hear the seatbelt realease from behind your head when you unbuckle. My question to anyone who has done this b4 is, if i cut into the harness and just run that Brown wire W/ 2 silver dots straight to the plug that connects to the car, will everything with the seatbelt still work properly.. Without tripping the light in the dash as well??
Yeah I pulled the wiring harness out of the old seat and used electrical tap to tape up the plugs I wasn't going to use. The only one I need was the one to plug into that silver box under the seat.
boostd4
SC- 1st Gen (1992-2000)
10-12-11 11:48 PM
