possibly buying an sc300/400
Hi, I am looking into buying an sc300 or 400. I know all cars have common problems with them. I was wondering what to look for when I go to look at cars. What are some common problems that i can check? I have done a little research and i learned the motor mounts are a common problem? How can I check to see if those are ok when i check out a car?
1JZ Single SC400
Put the car in drive and push on the gas and brake at the same time, and see how far the motor moves.
List of common problems..
window regulators
control arm bushings
motor mounts
leaky headlights
power steering leaks, which takes out the alternator
cluster needles
climate control bleeds or turns black
fuel ecu
Thats all that I can think of off the top of my head. Good luck and try searching on here for your answers..
window regulators
motor mounts
leaky headlights
cluster needles
fuel ecu
美少女戦士セーラームーン
window regulators
motor mounts
leaky headlights
cluster needles
fuel ecu
window regulators
motor mounts
leaky headlights
cluster needles
fuel ecu
grego2
01-07-08 09:11 PM
