I happened to have the OE diagram and the plug letters are different from the ones on that website... just had to double check before I short anything else....
I used the info on the site for my whole install and it all worked perfectly the first time I turned it on. If you have conflicting info on the OE diagram I would probably just use a tester on all the wires while the car is off to see which pin the constant power is.
i have everything else worked out except for the power thing. The conflict was a ground cable and +B cable were in same spot if you look at the OE and the link. didn't want to short the radio thanx
