View Poll Results: Which Coilovers should i get
Voters: 48. You may not vote on this poll
Drifting Conversion Starts now!! Hooked Sideways from now on
#196
Actually i was thinking about it, i wanted a smaller one for quick spool and smooth response and not just hit me all at once with the big one, but i think i can learn with what i got now, if i cant...........ill get a smaller one.
i like the big turbo still just in case some new camaro SS decides he wants to play, and i still need to put him in his place
haha
#197
LOVE the Driveshaft from DM its a 1pc which i love. Also you would need the diff adapter(as pictured) from DM as well.. You wouldnt even need a new diff the diff adapter allows you to use it with your current diff in the SC...
#198
not sure about the power, every mechanic working on my car has been around supras for years and worked on many 800+ HP supras and 240s, and they said around 500, if not low 5's then HIGH HIGH 4's at 20lbs, but i plan on going 25 lbs
#199
NEW VIDEO: reving it a little bit just testing it. listening, monitoring...this weekend.............test drive! GOD LISTEN TO THAT TURBO!
http://www.youtube.com/watch?v=v2rMdQAyohI
Interior before, wood grain and tan. Automatic, thriple pillar to the left, Innovatice Motorsports wideband Greddy 60mm boost gauge, soarer steering wheel....
![](http://i906.photobucket.com/albums/ac262/driftnsoarer/Driftin%20in%20OKI/INTERIOR.jpg)
Interior After, wood grain, Changes: Manual R154 5 speed, AEM Wideband, DEFI 60mm Boost gauge, DEFI 60mm Water Temp Gauge, DEFI 60mm Oil Temp Gauge, DEFI Control unit, MOMO Steering wheel, NRG Steering wheel hub, Greddy shift ****.
![](http://i906.photobucket.com/albums/ac262/driftnsoarer/5%20speed%20swap/DSC02465.jpg)
#206
I have a GS rear Diff welded.....KAAZ is in the mail actually so that will be going in soon
I went with the Steel DS, i like the 1 pc solid steel alot better!
you have the 154 already? what shifter did you use? im having issues
#207
I don't have the trans yet. I was gonna do a 1jz swap and right now I'm starting to gather parts. If I get a 1jz from a soarer would it come with a r154 or a w58?
#208
direct qoute....
"The Toyota Soarers made from the years 1991-2000 were offered with a 4-speed automatic transmission for all models. In addition, the JZZ30 Soarer could be had with a 5-speed manual transmission which is the R154 MKIII Supra Transmission. It had a luxury feel to it, yet the 2.5GT twin turbo model in particular was truly a very powerful sports car as well. Not surprising though, given its 1JZ-GTE engine was used for the MKIII Supra as well.Both cars' suspension, brakes, drivetrain, and engine parts were interchangeable"
#209
#210
They did sell 2.5tt as 5 speed but only certain rare models. Every Soarer i saw in Japan was an automatic. The 5 speeds were custom built with a supra R154 MKIII transmission. Regardless they use the same engine and tranny so if it comes from a soarer or supra, its the same thing....
good luck with the build, and if you have any questions let me know..
