SC400 Crossmember for 2jz-gte
You can also use toyota Soarer motor and tranny mounts for those curious in the 1jz swap...
Im leaning towards a 2jz with a r154 man. tranny. But, I picked up a soarer fully complete with everything, just the car itself has been side swipped. So, everything I have in that soarer will bolt right onto my sc400 chassis, the only hard part of the swap would be the wiring...if I was keeping it auto.
To my knowledge, the 2jz swap needs motor mounts from a TT motor, but you can use sc3 and soarer tranny mounts if you go with the r154. Past that is up to you really, I would suggest a rebuild kit, and other things of that nature. But if you chose not to, than thats your own way of doing things.
Schwieg
Schwieg
