SC- 1st Gen (1992-2000)
SC400 Gas Level
Old 02-15-10, 10:54 PM
rbigshow04
rbigshow04's Avatar
Default SC400 Gas Level
Well here it is my cars gas level seems to get lower and lower if i don't drive the car for a few days not sure what the problem is and I'm pretty sure I'm not going crazy lol.....Any ideas
Old 02-16-10, 02:34 AM
SpuGen
SpuGen's Avatar
Check your Fuel Filter for leaks?
My line rusted out and turns out I was leaking fuel from there.
Cut it out and replace with hoses + filter , or get new hardlines to fix it.
Old 02-16-10, 02:36 AM
Hil
Hil's Avatar
Try and measure your mpg over the next couple tanks. If it seems low you may have a leakage problem. If it seems normal than it's just deviation in your fuel gauge. Mine sometimes randomly drops a lot. I didn't use a bunch of gas then, it's just slight lag from previous use. Also when I go on sharp curves the needle drops visibly, probably due to the sensor in the tank
Old 02-16-10, 11:17 AM
BostonSC4
BostonSC4's Avatar
i just don't worry about mine. my needle deviates from the real amount by about 5 gallons. i know this because i know the tank is 20.8 gallons, and when i refill it at "empty" it puts in like 13-14 gallons and thats it. i think there is a way you can clear off the sensor in the tank though.
Old 02-16-10, 01:38 PM
rbigshow04
rbigshow04's Avatar
Thanx guys for the reply's. I got one more question is it normal when you go to the gas station and remove the gas cap and pressure is released from the gas tank
Old 02-16-10, 02:00 PM
vrsc400
vrsc400's Avatar
Yes. at least on all the cars I've ever filled. I don't think its being released though I'm pretty sure its a slight vacuum being filled.
Codger07
Performance & Maintenance
08-31-17 07:30 PM
imherenow
09-22-11 03:59 AM
LexGS
02-20-10 06:37 PM
disc400
06-15-09 05:26 PM
whitels
05-31-06 11:24 PM
Quick Reply: SC400 Gas Level
