One-year anniversary
#62
Will look into it... By the way, what is the gear on your LSD? I've been doing some reading. The one I saw here on CL was something like 3.76 and the one I was just reading at work over at Lextreme's website was 4.27. The guy claims that its better than 3.76. I'm still reading the pros and cons bettwen the two tho.
Got a link on that shift kit? I'll read about it and see whats up.
Thanks! As is your ride sir.
Thankss
#63
K.. will do. Do you know what the gears are on your LSD? Did you just use the stock one?
From Lextreme's forum
1993-1998 Supra TT manual - 3.133 (torsen)
1998+ Lexus V8 Cars VVTi - 3.266 (open differential only)
1990-1997 LS400 - 3.62 (open differential only)
1993-1996 Supra TT auto - 3.769 (torsen, 3.77 not the usual 3.76 quoted)
1997-1998 Supra TT auto - 3.769 (open standard, torsen available)
1992-1997 Lexus SC400 - 3.912 (open differential only)
1992-1998 Lexus SC300 manual - 4.08 (open differential only)
1997-1998 Supra non turbo - 4.08 (open standard, limited slip available)
1992-2000 Lexus SC300 automatic - 4.272 (open differential only)
1993-1996 Supra non turbo - 4.272 (open standard, limited slip available)
Did you then just put the torsen lsd and used the stock gearing?
