ashtray's got a secret..and I know what it is..
#77
Thanks for the kind words Carlos. Also when it comes time for your fuel pump, and we have a little more time, we can set you up with a blow through and that will help with the hesitation/low idle.
And I will let you know when I get in more LED's and I can get you setup with your HVAC and your brothers if he wants, and once I get everything set for the cluster, I will let you know and we can plan out a day/weekend so I can do your cluster too.
No problem. Cant wait till its running 100%
She does sound mean...ill post exhaust clip up later today after the exhaust is done.
#81
bolting everything into place
turbo mounted, and set, oil lines hooked up, DP installed
i/c pipe connected and installed
Finishing touches, open front on cam cover, again excellent job Carlos
Everything in place..first start up was done not 4 minutes after, but we failed and didnt get a video
One happy SC300.
One happy SC300.
Sweet!!!!
#84
#85
Getting ready to take her to get tuned, + Walbro install + 12v mod.
Edit: she's also now on blow threw. no more stalling issues. just needs to be tuned for boost. Vids of rolling and WOT will be up soon.
#88
well again we failed to get video, but we did one better sort of...now I dont know how accurate the dyno app is for the the G1/Iphone, but after laying the smack down on a G35 from a stop and roll, we came up with this:
yes it says 1992 SC300 and the date is way off (my fault), but it was preset in the phone, had the weight correct and seems to be right on point and fairly accurate.
321hp/402ft lbs tq...which in theory with stock compression @ 9psi the SC300 should make 310-330rwhp..
