alarm install questions... already tried searching
My viper 5701 autostart/alarm came today in the mail. I plan on installing after I get my car back from autobody.
Is there a how to/ DIY on the forum for installing a alarm/remote start in a 92 sc300?
I searched and I couldn't find anything. I searched google also and only found wiring specs, but not all the wire locations I need.
I wanna try installing it myself, has anyone else accomplished this? I have a manual tranny and will be installing autostart on it, the alarm is made for 5speeds so shouldnt be that hard right?
I contacted Tommy at autobox in El monte ca as referred to on the forum, he said he charges $200 and will take 4 hours. Should I just go that route? Im use to and familiar with installing car audio, so doing the alarm shouldn't be that difficult with a DIY.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery BLUE/YELLOW (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna PINK/GREEN (+) RADIO HARNESS
Amp Turn On PINK/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE
RF Speaker (+) RED
LR Speaker (+) WHITE
RR Speaker (+) BROWN
Amp Location RT SIDE OF TRUNK
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger RED/WHITE (-) BELOW FUSEBOX "WHT PLUG"
Trunk Trigger RED/WHITE (-) DRIVER'S RUNNING BOARD
Hood Trigger N/A
Alarm Disarm GREEN (-) DRIVERS KICK PANEL
Parking Lights DARK GREEN (+) DRIVER'S KICK "WHT PLUG"
Convenience
Headlights-Lo RED/GREEN (+) STEERING COLUMN HARNESS
Trnk Release BLACK/SIL (+) DRIVER'S RUNNING BOARD
Remote Start
Ignition 2 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
Accessory 1 PINK/BLUE (+) IGNITION SWITCH HARNESS
Anti-Theft Descript NONE
Tachometer BLACK (-) AT IGNITER PASS FENDER
Brake Lights GREEN/WHITE (+) AT BRAKE SWITCH
Reverse Lights RED/BLACK (+) IN HARNESS IN DRIVER KICKPANEL
Horn GREEN/RED
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock GREEN/WHITE (-) NEGATIVE TRIGGER
PowerLock GREEN/YELLOW (-) DRIVER'S KICK PANEL "BLU PLUG"
LF Window Up LF:RED
RF Window Up RF:RED/BLUE
LR Window Up LF:GREEN/YELLOW
RR Window Up RF:GREEN/WHITE
LF Speaker (+) BLUE
RF Speaker (+) RED
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
Hood Trigger N/A
Convenience
Remote Start
Horn GREEN/RED
Modules
WIRE LOCATION
Doorlocks/Windows
LF Window Up LF:RED
dude i have teh exact same alarm and its been sitting in my car for 2 months, cause i dont want to pay 300 to install that thing lol....please do a diy lots of pictures, and this wire went to this wire if you do it lemme know...i saw all the wiring and i was like ehhh not so much...and yeah i work on ea6b prowlers in the navy this $#!t just didnt make any sense to me lol
once you do one remote start(or 5) you can do them all.
i would say if you have never done one them get someone experienced to help or leave it to the "experts"
i use expert in quotes since a lot of people claim to be one but not many can prove it. a lot of people can wire it all up and have it work but doing a clean wiring job is a different story.
to be able to do a remote start you have to understand what each wire in the system does and how it reacts to other functions.
you dont need a special remote start to do it in a manual trans cars. just jump the clutch switch. you car will also be able to start without depressing the clutch. thats actually a good thing when you thing of it with regard to thrust bearing wear and crank walk.
Don't mean to bump a old thread but...
I decided to get someone to install it. I found another trust worthy spot, where I get all my cars windows tinted at. They are charging $175, a bit cheaper then the spot I found before.
Is $175 a good price for alarm install?
pimpin gs
01-31-07 09:49 PM
