SC- 1st Gen (1992-2000)
***OFFICIAL: POST a Pic of your ride - RIGHT NOW! SC Style***
Old 09-01-12, 01:40 AM
  #1621
PeteSoarer
PeteSoarer's Avatar
Originally Posted by KingPhilip
I'm sorry, but I don't really see it making a difference, because I already hammered that entire part of the seam upward, and it is still level with the further inner part, which the tire will still hit even if you cut/grind out that part of the seam. Besides, the SC runs really crappy already at my height, and it's not even that low compared to CSPhoto's yet.
Not flaming, just saying.
It helps a bit cos there is so much camber at that point when tire hits the frame. With bigger wheels and tires (bigger wheel/tire diameter) benefit is lesser because tire hits the frame "earlier" so camber is "smaller". Frame has also some edges pointing down that gives an half inch more clearance after cutting those down. Anyhow it helped me at scraping issues and tire doesn't rub to frame anymore.
Old 09-01-12, 06:15 AM
  #1622
GotRiceYo
GotRiceYo's Avatar
Originally Posted by vinh
Switched back to a less aggressive 18" setup for more sidewall and tire clearance
Can has both please??? K thanx
Old 09-01-12, 09:02 AM
  #1623
BSanders22
BSanders22's Avatar
Random iphone shots for fun. The owner of this 88 Corolla GTS followed me into the gas station to ask about my wheels, tunred out to be a really nice guy and his little Toyota was sharp, clean as a whistle.
Instagram shoots FTW
and my fujin lip is still in the basement, I'm dragging along, but it'll be on the car soon!
Old 09-01-12, 01:39 PM
  #1624
skirts
skirts's Avatar
Jintei what wheels are those?
Old 09-01-12, 01:54 PM
  #1625
dlsoul87
dlsoul87's Avatar
Draining the fuel tank and fixing a leak...
Old 09-01-12, 02:08 PM
  #1626
OG Dada
OG Dada's Avatar
that makes sense. If you are running that much camber the wheels/tires would be in an angle and the outer part would be sitting higher. But then again, I don't wanna run that much camber for a daily driven SC.
Old 09-01-12, 06:17 PM
  #1627
CalitriSC
CalitriSC's Avatar
The cutting does help with any rubbing and gives more clearance. I cut the same on mine and pretty much have zero rubbing now unless its a huge dip on the freeway or something. I daily mine very low with no crazy camber. And it was on three road trips to Cali over the summer
Old 09-01-12, 06:43 PM
  #1628
FAT HEAD
FAT HEAD's Avatar
here's mine... just felt like snapping a photo for some reason
Attached Thumbnails ***OFFICIAL: POST a Pic of your ride - RIGHT NOW! SC Style***-sc400-13.jpg
Old 09-01-12, 08:24 PM
  #1629
DreaMzZ
DreaMzZ's Avatar
This is mine!
Old 09-01-12, 08:32 PM
  #1630
chrisindub
chrisindub's Avatar
OK. So you have done the same as me and couple of other members. You can't really go lower than that unless you do something extreme to front frames.
That is some aggressive trimming. Any pictures of what that will do for your ride height?
Old 09-02-12, 12:18 AM
  #1631
PeteSoarer
PeteSoarer's Avatar
Old 09-02-12, 12:22 AM
  #1632
ZSC3
ZSC3's Avatar
Damn clean set up man, what are wheel/tire specs?
Old 09-02-12, 12:32 AM
  #1633
PeteSoarer
PeteSoarer's Avatar
Thanks. 18x10,5" -2 and 18x12" -3. 225/40 and 265/35 Achilles ATR. Max oem camber in front and rear i have adjustalbe upper control arm with a bit too much camber.
Old 09-02-12, 04:49 AM
  #1634
chrisindub
chrisindub's Avatar
Really nice work..........
Old 09-02-12, 08:51 AM
  #1635
BSanders22
BSanders22's Avatar
Here's a DSLR shot from today
Quick Reply: ***OFFICIAL: POST a Pic of your ride - RIGHT NOW! SC Style***
