Un-installing Defi gauges / Apexi SAFC II
The safc is easy to remove depending on how it was installed. There is only one wire on the ecu/harness you will need to splice back together, everything else can be clipped coming from the safc harness..
to make life simple, take a really good picture of the ecu and safc harness if possible, pm it to me and I can edit/mark the picture for you and walk you through it just to make sure nothing is looked over.
As for the gauges, I have no idea..would like some Defi gauges, but Im cheap and no body will sell them to me for $100.
The DEFI gaugfes are daisy chained together if they are the older style "Link" type. So, each one is connected to the next, and they all depend upon the DEFI Link controller to operate. Each one has a wiring harn ess that you need to connect to in your car. If you have the newer style gauges, they still have individual wiring harnesses for each gauge. Disconnect those and reconnect to your other car. You will obviously need to tap into power, and ground everything.
GL
Ryan
GL
Ryan
bryan767
SC400 / 300 Classifieds
04-17-12 05:22 PM
